Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 2012 Switchback .I have a D&D exhaust and a SE high flow breather.I have started to get codes for O2 sensors front and back.Had them changed out and reset codes and went 80 miles and the codes are back on.Bike runs good has a little popping on deceleration but not bad.I do not have a tuner.Anyone can help me out I would really appreciate it.Thanks
I just talked to the tech at harley Davidson and I was wrong I thought he changed the sensors but he changed out the engine temperature sensor. He said he hooked up the 02 sensors and they checked out ok but the engine temp sensor did no so he replaced it.Thanks
If you get a code indicating rich or lean, the O2 sensors are very likely working correctly but you have an air or fuel issue.
Intake or exhaust leaks, low fuel pressure and injectors plugged can cause lean codes.
The best thing you can do at this time is to get a tuner. The bike will run so much better (unless you're happy with just "runs good") and then you can worry about the small stuff
