Stealership Probs
Old May 16, 2007 | 10:06 PM
rwagon57's Avatar
rwagon57
Default RE: Stealership Probs
It leaks, make them fix it, that's why there is a warranty. New motorcycles from any brand are not supposed to leak.
Old May 16, 2007 | 10:12 PM
the_icemAN's Avatar
the_icemAN
dansflhti that means it is weeping. When it begins weeping .... then seeping.... and then leaking.
Old May 16, 2007 | 11:37 PM
TowJam's Avatar
TowJam
One of the updates for the '07 touring models was to incorporate fully integrated oil lines in the powertrain. This is supposed to eliminate leaks and weeps. If you're seeing oil on the outside of the engine - regardless of how little, it's a problem and should be fixed under warranty. As someone else already posted, weeps turn into leaks.
Old May 17, 2007 | 12:55 AM
hogdoc's Avatar
hogdoc
There are no oil lines between the motor and trans on the '07's. There is an aluminum gasket with silicone beads around the ports. We havent seen anything like this yet but that gasket is the problem. The neutral light problem has been an ongoing issue since the '07's came out, tech services told us to tighten the neutral light switch in 5 ft lb incriments until the problem stops. I've found that about 28ft lbs has taken care of this. But work up to it from 20 ft lbs. You DO NOT want to break off the switch in the case. Take the switch out, clean it with brake cleaner then OIL the o-ring so it doesnt tear, then start at 20 and work up. Hope this helps.
Old May 17, 2007 | 01:27 AM
Fishpart's Avatar
Fishpart
I have an 07 EG with same issue, 8000+ miles and I just thought is was normal, I guess I'll need to get that gasket replaced, thanks for the post.
Old May 17, 2007 | 08:35 AM
Madav8tr's Avatar
Madav8tr
Great information Hogdoc. I don't have any problems with the nuetral light on my '07 Street Glide but if one ever manifiests itsself, I now know a possible solution. Maybe it will save me a trip to the dealer too.
Old May 17, 2007 | 10:23 AM
bulldogmoe7's Avatar
bulldogmoe7
ORIGINAL: hogdoc
your right i got informed by the dealer yesterday that there is a gasket. mine should be done today and i will pick up on friday morning. i was told be the service writers there was a tube. they also told me that mine was broken in an unusual spot. i will see it tomorrow
Old May 17, 2007 | 11:04 AM
07bluprl's Avatar
07bluprl
Thanks guys.. I will be having that fixed or i will be havin a new bike! Yall are right... its more like weeping out and you cant see it till dirt sticks to it. I will def have that fixed.
Derek
Old May 17, 2007 | 02:17 PM
bloozeman2002's Avatar
bloozeman2002
Can someone post a picture of the spot where the "weeping" occurs? I'm at 6,500 miles on my 07 Ultra, and I'd like to keep an eye on this!
Thanks
Old May 17, 2007 | 02:51 PM
Kahuna's Avatar
Kahuna
Tow Jam et al,
Although the '07 has intergrated oil lines, you still, however, have the primary shaft seal that can leak!
Harley eliminated the starter shaft seal, but not the primary shaft seal! This leak can occur any time at any mileage. I have an '05 Road Glide, and had to have it replaced twice so far.
This is a common problem with baggers and dressers. The dealers are quite familiar with this.
ORIGINAL: TowJam
