Largest Diameter Rear Wheel
Old Apr 14, 2016 | 02:36 PM
xk49's Avatar
xk49
Default Largest Diameter Rear Wheel
Getting ready to make the plunge on a front 21x3.5 wheel for my 2007 Road King. I would like to get a matching rear wheel at the same time, but I'm not sure on the size. I would like for both wheels to have as close to the same profile of side wall as possible. Can I run a larger wheel diameter wheel out back, and if I can, what size are people running?
Sorry if this has been asked a million times, but when I search I get 1000 threads of misc. wheel topics.
Old Apr 14, 2016 | 06:13 PM
Robjr's Avatar
Robjr
I have a 05 Eglide and I have a 18x3.5. I know you can go 18x4.25, but I'm not sure the tire size you would need.
Old Apr 14, 2016 | 11:11 PM
ATRannals's Avatar
ATRannals
Default Limiter is going to be tires
I'm looking at the same 21x3.5 on the front, but my big problem is the tires. I've got to have the whitewall look on my RKC. Avon finally released a 120/70-21 whitewall that would be perfect. I've seen multiple people use it with the stock fender and it really looks good.
The problem with the rear wheel is that the only larger whitewall tire I've seen so far is from some Chinese vendors and I don't know much about them. If only Metzeler or Avon made an 18 inch rear whitewall. I have seen some people go the custom tire whitewall for show bikes, but I ride mine and want a good, safe and dependable tire under my butt without spending insane money.
Looks like I'll be sticking with the stock 16 on the back for now, but not too disappointed as you can barely see any of the rear wheel anyway.
Best of luck with the new wheels and tires.
Old Apr 14, 2016 | 11:52 PM
Guntoter's Avatar
Guntoter
Just put a 16X3.5 on the back. It will look far better than those 18" wheels. You can also run stock size rear tires with no problem. The goal with a 21" front is to have it look taller than the rear. Otherwise it just looks goofy with front and rear wheels that both appear tall, in my opinion.
Old Apr 15, 2016 | 01:47 AM
G E E's Avatar
G E E
I'm running 21/18 setup on 07 RK the back is 18x 3.5 with Metzeler ME880 Marathon 150/70B18 Rear Tire, that biggest widest tire your going to get in 07 swing arm....
Now it I did it again I just do 16 X 3.5 and be done. It cheaper , rides smoother, and no one see $1500 back there anyways.
Old Apr 15, 2016 | 02:56 AM
RKZen's Avatar
RKZen
I am running 21" front and 16" rear. IMO, I would stick with an OEM size in the back to keep a high profile sidewall tire for a cushier ride.
Old Apr 15, 2016 | 05:04 AM
grbrown's Avatar
grbrown
RKZen's photo shows us all we need to know, showing off his white-walls! I have squeezed a Deuce disc rear wheel in my bike, but that is only visible to someone who knows his Deuces, as only the edge of the disc is visible.
There is very little difference in rolling diameter of most wheels that will fit our bikes. The 21" is a little larger than stock, but all sizes used by the MoCo are as near as matters the same. As for rear wheels, same comment applies. If there is a suitable 18" rear WW, it will simply have a narrower WW!
Old Apr 15, 2016 | 07:10 AM
jmaniace's Avatar
jmaniace
[QUOTE=G E E;15045609]I'm running 21/18 setup on 07 RK the back is 18x 3.5 with Metzeler ME880 Marathon 150/70B18 Rear Tire, that biggest widest tire your going to get in 07 swing arm....
This is true and not at the same time. You can run a 180 in a '07 stock swing arm but the limitation in your stock fender. You can run a 160 if you get the wider rim and trim the belt guard but you wont be able to find a WW tire in that size at lest not from Avon.
So my answer would be to run to stock rim size and get the 150 WW from Avon and call it done. Here is Avon's tire chart which I'm sure you have seen all ready.
http://www.avonmoto.com/products/cru...ustom/cobra_ww
Old Apr 16, 2016 | 10:10 AM
multihdrdr's Avatar
multihdrdr
If you're going to stay with a 16" rear and want a WW, then everybody makes a 150/80-16 WW or without WW.
If you don't care about the WW, then everybody (the big guys) makes a 150/70-18
Old Apr 16, 2016 | 10:36 AM
xk49's Avatar
xk49
Not that I'm racer and I probably wouldn't notice the difference anyways, but by running two different side wall heights doesn't that mess with the feel of the bike when corning?
I do want to run WW's, so having a good tire brand is important. Thanks for all the info. RKZen's bike looks good with the mixed matched sidewalls. I'm still exploring the matching sidewall option that GEE pointed out.
TroubledWine
Oct 9, 2021 07:01 AM
scot210
Jul 19, 2015 07:00 PM
tsport117
Wheels/Tires
11
Mar 24, 2013 06:44 PM
hddee
Oct 11, 2012 12:03 PM
harris48cars
Jun 20, 2007 01:59 AM
