Very simple, stock Sirius mount with double side tape, antenna is inside the fairing on top of the stock radio, power is tapped into a key'ed wire, and the aux. input is used on the radio for better sound.
i'vegot great reception with the antenna mounted on top of the radio, mounted under the fairing. thought i had a problem with the antenna because the signal kept cutting our on my Sirius. Finally found out it was a bad connection between the sat radio and the sirius cradle. replace both, and since the sat radio just slides into the cradle with a plastic switch lock, i use rubber bands wrapped around the radio and cradle to keep the radio from walking out of the cradle.
