Loading & unloading my scoot onto my Harbor Freight M/C table had a pucker factor of a 9.9 out of 10 for not having a place to put my feet to steady the scoot. So this is my quick 'n dirty fix for a place to put my feet.
My parts list consisted of:
4 ea. "U" shaped steel brackets.
8 ea. 3/8-18 Galvanized Hex Head bolts, lock washers and nuts.
4 ea. 2 x 4 x 16" pine studs.
Parts cost about $27.00.
I positioned 2 brackets per side. One 13" from the wheel chock end to the 1st bolt hole C/L and 8.5" from the back end to the 1st bolt C/L, both flush with the table edge. I drilled 2 25/64" (.390) holes thru the table for each bracket. I then bolted them from under the table. I used my Harbor Freight pickup loading ramps as my outrigger platforms. The slotted and perforated ramp gives great footing and traction. Once the scoot is loaded I take the ramps off, pull out the 2 x 4's, attach the jack foot pedal and raise the table.
I am getting the same thing and it's pissing me off. That wasn't the case when I posted this last spring.
Try this:
Right click over pic.
Select open Link in new tab.
The pic will appear in a new tab.
I'm gonna blame Windows 10 for this one.
Not windows 10, I have Windows 7 and same thing
It's also happened on several other threads with me trying to open thumbnails
I'm think it's the website
did about the with 2x4s and plywood. after the first ride on and hitting the tire holder me hanging half off the seat trying to find the floor I new something had to change.good work.
kroozeabout.
