Thundermax vs Screaming Eagle
Old May 8, 2016 | 08:07 AM
Sarge1's Avatar
Sarge1
Default Thundermax vs Screaming Eagle
i am considering switching to Thundermax. I currently run a SE. I have heard that once its married to an ECM, that it can't be used on another bike. If I switch to Thundermax, it replaces the ECM.... So can that ECM be easily married to another bike of the same year and can you use the SE tuner?
I hope this makes sense.
Old May 8, 2016 | 10:14 AM
hullhorr's Avatar
hullhorr
I believe the answer to your question is yes. The Thundermax is not married to one bike once you use it. Not sure about the SE tuner. The Thundermax is a great product.
Old May 8, 2016 | 10:30 AM
Rick's Ultra's Avatar
Rick's Ultra
Sarge,
You are right about the ThunderMax. It is a very nice piece of gear. You can move it from bike to bike as it is not married to the bike. It replaces the ECU in the bike. Nice thing is it has the ability to grow with your bike as you introduce new variables such as a new cam, different throttle body, different exhaust, etc.
It was an expensive tax to pay, but, ever since I went with Thundermax and learned how it works I have been extremely satisfied. I wish my bike would have run this way from the factory.
I went this way as I read that the SE tuner was married to the bike and could only be used with that bike.
Old May 8, 2016 | 06:58 PM
skydude426's Avatar
skydude426
I also went to a Thunder Max after having a SE race tuner. I liked it so well I have one on both my bike and my wife's bike. I've made changes to both bikes and saved a lot of money on tuning. Once you learn how it use it, you have complete control of your own tuning and it's not hard.
To answer your question, the Thunder Max can be moved to another bike as it is a replacement ECM. The SE tuner marries to the bikes stock ECM and will only work with that ECM.
Old May 8, 2016 | 09:25 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
imo both old tech.should read fp3 vs power vision.
Old May 8, 2016 | 09:26 PM
bigskyroadglide's Avatar
bigskyroadglide
For the SE, if you move the actual ecm(original bike) to another bike, replacing that bikes ECM(destination bike), the SE can be moved. Just dont expect the tuning to be correct unless the exact same component's are installed on the destination bike.
I did this when i replaced a 2009 bike's ecm with a thunder max. Traded my old ecm with se tuner to a friend for his ecm and cash. His bike ran fine after he tuned for his equipment. He did not buy a new tuner the dealer just modified the existing tune.
Old May 10, 2016 | 06:27 AM
CDN. RG's Avatar
CDN. RG
Thundermax is a great product,I installed one this spring (309-460)which is the latest version for my bike,my 113 has never run so good ,wish I would have done this ages ago but I had read that you will leave power on the table when using the t-max so I went with a flash tuner and was never really happy with it and the tune was never really right ,the t-max tunes where you ride and the bike will run really well in those areas which is what it is all about,the key is don't take it to a dyno tuner to see how much power you are making because you may be disappointed ,just load a close map and let it do it's thing and enjoy a smooth running powerful bike.
Old May 10, 2016 | 06:43 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
If your on the fence, let me confuses you a bit more.
May I consider you take a look at TTS Mastertune Turner.
A lot less expensive then a T-Max and light years better then a SE Turner.
YB
Old May 10, 2016 | 07:42 AM
kishstl's Avatar
kishstl
and we're off......
Old May 10, 2016 | 08:19 AM
flanigans45's Avatar
flanigans45
T-MAX made more HP on my bike than SE tuner .HD tuned my St 4 got 106 HP /111 TQ put t-max on got 115HP/122 TQ. Then upgraded to St 5. Run so good I haven't run on dyno.
