Oil/lube suggestions
Old May 24, 2016 | 06:47 AM
Pgh-mike's Avatar
Pgh-mike
Default Oil/lube suggestions
1997 FLHTC rebuilt transmission,motor not run in 8 years. Would appreciate some suggestions for lubricant in gearbox and primary.
Old May 26, 2016 | 07:43 PM
HDSAE60's Avatar
HDSAE60
HD Formula + in primary and Red line Shock proof trans fluid.
Old May 26, 2016 | 08:17 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
cheepest crap u can find, u should dump it after it runs about 20 minutes. then again at 10000 miles. then put the good stuff in it, with a bike of that age i would stick with dyno oils. the synthetics find their way out of old dry cork gaskets faster the dyno oils.
Old May 26, 2016 | 09:49 PM
jammerx's Avatar
jammerx
No synthetics
Old May 27, 2016 | 01:48 PM
TUCCI's Avatar
TUCCI
Oh goody an oil thread. Ok I'll play; I use Rotella T6 in the primary and any synthetic gear oil (no cheap stuff) in the 75-90 viscosity. Side note; Without investigating with an oil analysis, I've found Rotella T6 to look and feel identical to the HD formula+. I think it's the same product but won't spend the coin to have both analysed.
94 ultra
Jun 15, 2017 07:24 PM
jerryw618
Jun 12, 2015 08:34 AM
Bedore
May 6, 2011 11:31 AM
103Eagle
Jun 25, 2009 12:42 AM
freebyrd
Nov 10, 2008 06:50 PM
