check engine light
Old May 30, 2016 | 05:42 PM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by fchalker1981
The instructions were not visible
I would think if it's a true fault, it would set a code and the light would stay on.
Do you have an oil light and the oil pressure gage? If not, unhook the the plug going to the pressure sending switch located just behind the pushrod tube on the right side and see what happens.
Old May 30, 2016 | 05:44 PM
fchalker1981's Avatar
fchalker1981
2nd Gear
Yes I have the gauge and the check engine light I will try that a d see
Old May 30, 2016 | 06:53 PM
Jackie Paper
Still do not quite under stand what you are saying here and I cannot tell in the service manual how it all works. Appears you only have one rheostat type sending unit. My guess is if you have a separate oil pressure light, you would have another sender or the rheostat one would have more then the two wires your's shows on the rheostat in the manual. My bike has a yellow check engine light and a separate red oil pressure light.
Old Jun 13, 2016 | 11:34 AM
DG422's Avatar
DG422
Originally Posted by Vernal
Check to see if you have any codes:
https://dgcustomcycle.com/tech/harle...es-04-present/
that is a great resource, thanks for posting!!
Fugly
Aug 3, 2012 08:17 AM
Bop49
Jun 18, 2012 04:48 PM
G wizz
Jul 29, 2011 05:05 PM
tekeum
Jul 14, 2010 08:55 PM
gatorwalt
Jul 24, 2008 10:26 AM
