breather bypass filter
Old Jun 13, 2016 | 07:50 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default breather bypass filter
Is a filter really needed with a breather bypass? Most if not all kits that I see have a filter included.
Old Jun 13, 2016 | 08:29 PM
qtrracer's Avatar
qtrracer
The 1 way valve in the rocker box should only allow venting in 1 direction, out.
Old Jun 13, 2016 | 08:33 PM
dawg's Avatar
dawg
No filter on mine, tube runs directly to the ground. Nowt a problem yet.
Old Jun 13, 2016 | 10:30 PM
C908's Avatar
C908
I also run mine to the ground, no filter no problem.
Old Jun 13, 2016 | 11:32 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
There are 3 options.
1. Run both of the breather hoses to a tee and then into a catch can.
2. Run both of the breather hoses to a tee and then into a filter.
3. Run both of the breather hoses to a tee and then to the ground.
Old Jun 13, 2016 | 11:36 PM
crimson13's Avatar
crimson13
No filter ,strait to the ground 18k miles no issues
Old Jun 14, 2016 | 11:35 AM
qtrracer's Avatar
qtrracer
Or use a "Y" instead of a "T"
Old Jun 14, 2016 | 01:24 PM
rpking's Avatar
rpking
4. run each hose to the ground skip the T
Old Jun 14, 2016 | 01:28 PM
OldPhat's Avatar
OldPhat
DK Customs put a filter in the kit that I got, so I put on the hose, because it was there.
Old Jun 14, 2016 | 07:48 PM
TUCCI's Avatar
TUCCI
No can, just run it to atmosphere. You can feel a constant stream of air being blown from the hose I don't see why it should be obstructed.
