My DYI filter relocation with pics
Old Jun 23, 2016 | 02:18 PM
TUCCI's Avatar
TUCCI
Thanks everyone. Putting filters in stupid places is all too common. It's up to guys like us to reverse engineer a product already on the market making it fit to our specification.
Here's a closer pic of the filter in place, it's the closest I can get without too much distortion.
By the way, how do I go about enabling a thank you button?
Old Jun 23, 2016 | 02:29 PM
TUCCI's Avatar
TUCCI
Originally Posted by beary
You probably don't know the answer, but how will your filter mount work for stock crossover pipe and the left side exhaust?
Beary
Beary, It would be a matter of using another small bracket to move it out from my current location. If I had to move it out, I would use a block of aluminum with longer bolts to pull it away from the swing arm (1" would go a long way). To use anything else would make for too much vibration to the filter housing. The more solid the fixture, the less integrity decay will be caused by jarring etc.
Old Jun 23, 2016 | 05:56 PM
buell95's Avatar
buell95
Originally Posted by TUCCI
Thank you very much I owe a debt to the Forum to post detailed mods like this after countless times I've learned from others who have done likewise.
The main reason it's advisable to have the filter length-ways instead of up and down is the bottom of the filter would likely scrape on turns especially with a full size filter which is what most people run.
By not having to worry about clearing the left pipe my bracket allows for maximum stealth. Any shape of bracket can be formed to the specification you are trying to achieve, remembering you need ample room to run you oil lines. I used hardware laying around the shop and you can use just about anything as long as you don't go too thin as the bounce and vibration of the road will cause an issue. The kits available cut around the motor mount but I went over the top to gain more bracket strength. By removing the plastic cap one of the fastener bolts shaved round can fit inside that cavity.
If you look at pic #2 in second post, you can see how beefy the bracket is. I can't depend on thin flimsy hardware especially if I decide to use a full size filter in the future. If you've ever removed the floorboard, then removed the bracket surrounding the motor mount you will see by looking at my bracket how it uses the bolts to hold the bracket in place. Their a bitch to remove initially as they are locktite'd in.
The flexibility is limitless. By using the location that most use, you can make it fit with any exhaust system as long as you don't mind it sticking out further. I tend to be **** and want every line to follow the lines on the bike.
You did a nice job with this I used some of Dan Moores product and mounted mine in the same place but vertical, I don't use it for a oil filter though I converted mine to a breather catch can. even though it is vertical I have never scraped. again great job.
Attached Thumbnails My DYI filter relocation with pics-2015-04-04_11-46-43_44-1-.jpg
Old Jun 24, 2016 | 12:03 AM
Bikeagraman's Avatar
Bikeagraman
Thanks, Tucci. It is very clear now. I think the best way for me to determine if the assembly will fit my bike is to actually make one and hold it to the bike to see what kind of bracket I need to fashion. Need to go shopping now! :-)
Old Jun 24, 2016 | 03:43 PM
TUCCI's Avatar
TUCCI
Yeah that's what I did, in fact the original prototype didn't make the cut and I had to redo it. Let me know if you need any pointers, I'm happy to help.
Old Jun 28, 2016 | 11:24 PM
buell95's Avatar
buell95
Deleted wrong thread.
Old Jun 29, 2016 | 07:31 AM
Zerk's Avatar
Zerk
Hopefully the pump can pump that far.
Seems an awful idea to me and a waste of time.
Old Jun 29, 2016 | 02:58 PM
TUCCI's Avatar
TUCCI
Old Jun 29, 2016 | 03:02 PM
wscott's Avatar
wscott
Originally Posted by zerk
hopefully the pump can pump that far.
Old Jun 29, 2016 | 04:06 PM
Zerk's Avatar
Zerk
The oil has to pump another 4 feet. Do you think Harley over designs their oil pumps cause they like giving their customers extra?
Exposed hose, that will probably be fine, but is another potential to fail. I carry spare hose. But not enough to repair that. I'dd add a hose splice.
All this so you don't have to spray the front of your bike with some brake clean.
