Bad Backs and Riders Backrest
Old Jul 10, 2016 | 01:01 PM
  #41
Cozz's Avatar
Cozz
Default HD parts
Originally Posted by DanHappy
What brand /model did you end up with?
It's the oval shaped Harley backrest. The two pole, spring in between type. Got it from craigslist, mounting bracket from local dealer. I see some for sale here, occasionally. I think I've got about a hundred bucks in it. Looks like a good investment.
Old Jul 12, 2016 | 12:11 PM
  #42
dynoflyer's Avatar
dynoflyer
Vertebra fracture 30 years ago, painful on long rides. I found a backrest and highway pegs set close enough (knees bent a bit) allows me to push back against the backrest and stretch my lower back while riding. Makes all the difference. Also, upgraded to Progressive monotube up front and 944's on the back. Has made a big difference for me.
Old Jul 12, 2016 | 02:12 PM
  #43
Streetrunner's Avatar
Streetrunner
Just got my X-ray report. No fractures or disk problems. Normal arthritis for my age. The determination is its a muscular problem. Going to do some therapy.
I have been reading all the posts and see that those who press their back against a backrest while ridding seem to get some relief. I'm guessing that it prevents the back from banging against it when hitting a bump. Sort of like riding in a car. I can't wait till the soreness subsides a bit so I can ride again. I'm going crazy just looking at the bike in the garage.
Old Jul 14, 2016 | 08:21 AM
  #44
Cep10SG's Avatar
Cep10SG
I've had 3 failed Fusions at L5-S1. 2 TLIF surgeries were "back to back" (pardon the pun) because the Dr accidentally punctured my dura and caused me to leak spinal fluid. This leak also ended up giving me Bacterial Meningitis. They had to put me under again 4 days after my first fusion to fix the problem, and hope I make it through. After breaking the fusions because I stretched after falling asleep I'm always in pain. I can tell you that I hated my back rest until I adjusted it to where it was comfortable and my wife made me change the seat because she hated the original seat. My highway pegs are low so I can push against them and relieve some pain. I can tell you that I've even kicked my seat a few times while just trying to get my leg over the seat. I got a deeper seat that gave me more comfort and made rides bearable, and I don't ride with anything in my back pockets, you may not believe this but a simple wallet can turn your hips just enough to apply pressure on your lower back and can possibly drive you insane on a long ride. Just like everyone else, this is just my opinion and my personal experience. I know what it's like to ride and have back pain. look at a different seat, adjust your backrest until it make YOU comfortable and maybe check out different shocks to give you more travel on bumps. I'll have my forth, and hopefully last attempt at a "360 fusion" (#2) when we get back to the States. we'll see how that turns out or they'll make me wait again. in the mean time my only "relief" is more pain. since I'm still on Active Duty I run 3-4 miles daily to numb the pain and not take pills.
Anyway, I hope you're all feeling better and don't wait until it's worse.
Cep
Old Jul 14, 2016 | 09:51 AM
  #45
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by Streetrunner
I recently injured a muscle (mid to lower) on the right side of my back. I went into a dip and it jarred my back so bad it hasn't been right since. I have a riders backrest that I seldom use because if I remember correctly, I stopped using it because it was irritating and uncomfortable on bumpy roads.
I'm wondering if I kept my back pressed tight against the pad if that would help support the muscles in my back. I'm sure there are many forum members who ride with back issues and I'm wondering what they have done to cope with the issue in order to keep riding. I have also considered buying a Kidney belt from a local moto-cross store.
Thoughts and advice please.........
Do you have the adjustable or the standard? I have 3 fused vertebrae at the base of my spine, so support is a good thing. I found the adjustable backrest to be "springy" and caused me to tense up. I now have the standard backrest set so that I can lean back against it with my arms straight on the bars. That allows me to sit forward if I want.
I also have my highway pegs set sort of high on the engine guard. This pushes me into the backrest so it doesn't get irritating.
It's like going down the road on a recliner
Old Jul 14, 2016 | 11:24 AM
  #46
SBates08's Avatar
SBates08
Originally Posted by Cep10SG
I've had 3 failed Fusions at L5-S1. 2 TLIF surgeries were "back to back" (pardon the pun) because the Dr accidentally punctured my dura and caused me to leak spinal fluid. This leak also ended up giving me Bacterial Meningitis. They had to put me under again 4 days after my first fusion to fix the problem, and hope I make it through. After breaking the fusions because I stretched after falling asleep I'm always in pain. I can tell you that I hated my back rest until I adjusted it to where it was comfortable and my wife made me change the seat because she hated the original seat. My highway pegs are low so I can push against them and relieve some pain. I can tell you that I've even kicked my seat a few times while just trying to get my leg over the seat. I got a deeper seat that gave me more comfort and made rides bearable, and I don't ride with anything in my back pockets, you may not believe this but a simple wallet can turn your hips just enough to apply pressure on your lower back and can possibly drive you insane on a long ride. Just like everyone else, this is just my opinion and my personal experience. I know what it's like to ride and have back pain. look at a different seat, adjust your backrest until it make YOU comfortable and maybe check out different shocks to give you more travel on bumps. I'll have my forth, and hopefully last attempt at a "360 fusion" (#2) when we get back to the States. we'll see how that turns out or they'll make me wait again. in the mean time my only "relief" is more pain. since I'm still on Active Duty I run 3-4 miles daily to numb the pain and not take pills. Anyway, I hope you're all feeling better and don't wait until it's worse. Cep
I know exactly what your going through. First surgery was L5-S1 discectomy and like yours my dura was cut during the surgery. It was repaired immediately but bacteria found its way in regardless. Spinal Meningitis damn near took me out of this world. It was so bad that I was in a coma for over a week and it made recovery so much worse. Have since had surgery on L4 and still deal with daily back pain. I never ride without a backrest and like "Shooter" I have my pegs mounted high. For me this setup alleviates the most pressure. I guess the worse part of having a bad back is dealing with people (employers) that have never experienced it. They have no clue what it takes just to get going in the mornings. Get as much exercise as possible, especially your core. Your core is what ties it all together.
Old Jul 14, 2016 | 11:28 AM
  #47
68 XLCH's Avatar
68 XLCH
Appropriate exercise, seating position and properly adjusted back rest, with the correct curvature to support the back, properly adjusted highway pegs, and possibly a kidney belt to help support the back.
90 percent of the riders will face this similar situation as they age, it's degenerative disease, arthritis. Others will have injury issues, all can benefit from the above.
Old Jul 14, 2016 | 12:00 PM
  #48
LazySundays's Avatar
LazySundays
I have a mustang seat and backrest. Also have a LePera seat and backrest which is actually a mustang backrest.
I'm wondering what exercises, that those who exercise the back, perform?
It's not as much about "back exercises" as it is about core strengthening, although stretching properly will help a lot.
Plank, done properly, is a great exercise. Just make sure that you push back through your heels to engage your core, otherwise it's just a shoulder exercise.
The best thing I ever did for my overall fitness and conditioning was to find a "Power Yoga"/Ashtanga Yoga class with a good instructor. It will improve your overall fitness level as well as teach you to focus on your core. It completely changed the way I work and do everyday things.
Any exercise you choose to do, remember, if your back hurts, you need to engage your core. If you remember that, you'll find you use your core more often and it will become more natural.
Old Jul 14, 2016 | 12:27 PM
  #49
rg_dave's Avatar
rg_dave
If there were one thing that would work then whoever came up with it would be rich beyond their dreams. Some guys swear by a backrest (myself included, standard backrest) and it causes pain for others. Good seat and good shocks are a given but finding what is good for you is the key.
Exercise can help in a lot of situations sometimes not. Find a good doc and rehab group that is focused on getting athletes back and they will typically get you going pretty quickly. Surgery should be the last option. I suffer from degenerative disc disorder as well as multiple spinal fractures over the years. I do about 20 mins of stretching a day. I do a lot of core work as mentioned earlier. I still lift heavy for me (squat, deadlift, etc...) once or twice a week and do a lot of work with kettlebells. I would have never thought that with my back kettlebell swings would help but they have made a world of difference I do at least 100 everyday. I did lose weight also, not saying anyone else needs to but it helped me.
Old Jul 14, 2016 | 12:40 PM
  #50
Hate Work's Avatar
Hate Work
A cheap exercise or two for the back? Stretch your back and hamstrings and walk up the stairs. And yes, the plank is a good low impact exercise as many have suggested.
