Cup Holder Doesn't Stay Put
Old Jul 17, 2016 | 07:48 AM
bagga's Avatar
bagga
a couple wraps of black electrical tape around the bars should do the trick.
Old Jul 17, 2016 | 04:06 PM
chief1600's Avatar
chief1600
Mine has rubber in both the upper and lower jaw. When I first put it on it didn't move. Now I can't get it to tighten enough to hold a 20 oz bottle it water. Can't physically tighten it any more without breaking it. The rubber is still in the jaws and seems the same as when I bought it. I'd like to get it secure and then I was planning to get a 21 oz Hydro Flask or something similar.
Old Jul 17, 2016 | 06:49 PM
YPD485's Avatar
YPD485
If you are using the same holder as in the OP's photo, the 21 oz. Hydro Flask will be loose in the holder. The 2 arms don't grasp the bottle with any tension and I think on a good bump, you will lose the expensive bottle.
Old Jul 17, 2016 | 07:03 PM
Spartanden's Avatar
Spartanden
Mine is on left bar and part of the lower clamp rests against the wires from the switch housing. No movement for me. But I would like!e something more robust that could hold something larger than the standard water bottle.
Old Jul 17, 2016 | 09:43 PM
chief1600's Avatar
chief1600
I am the OP. Good info about the Hydro Flask. I didn't know it would be loose in this type of holder. On the bright side I may have figured out something to make it stay put. I cut a 1" wide x about 4" long piece of the rubber liner out of a fire hose and used that between the bar and clamp. It seems pretty solid. I'll see what happens and go from there.
Timberwolf2017
Milwaukee Eight (M8)
Jun 26, 2017 10:33 PM
TexasMotorcycleRider
Oct 7, 2015 08:52 PM
jma100
Jun 1, 2015 09:19 PM
louisianaSVT2001
Nov 18, 2010 01:13 PM
DirtyWhiteBoy
Apr 24, 2007 05:37 PM
