Rotor bolts
Old Jul 19, 2016 | 05:57 PM
HOGNIT's Avatar
HOGNIT
Default Rotor bolts
just wondering if you all replace the rotor bolts after pulling rotors off, heard somewere that they are a one time use
Old Jul 19, 2016 | 06:02 PM
soos's Avatar
soos
I reused mine on my rotor change thousands of miles ago. I also remove rotors when I do my own tire changes just to avoid accidently warping or damaging a rotor when breaking the bead or removing the tire with tire irons and reuse the bolts.
Old Jul 19, 2016 | 08:16 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The bolts that hold the rear sprocket are a one time use item as they can stretch when torqued to the correct specifications and the possibility of shearing them off is real threat. The bolts on the brake rotors can be re-used if you're feeling cheap. Just remember safety first though!
Old Jul 19, 2016 | 09:00 PM
ROCKOUT Rocker Products
Sponsor
Both front & rear disc bolts on my '15 Limited Low are spec'd as one time use only. They come with a patch of something on them... threadlocker probably.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 19, 2016 | 09:01 PM
103 sedona orange's Avatar
103 sedona orange
http://partsfinder.onlinemicrofiche....EL%20-%20FRONT
Item #1 Qyt. 10 @ .99 cents (Ronnies .49 cents.) Front
Item #31 Qty. 5 @ $1.99 (Ronnies $ 1.49) Rear
Why wouldn't you buy new hardware? I suggest you read your HD Service Manual.
Old Jul 20, 2016 | 12:40 AM
bigfish_Oh's Avatar
bigfish_Oh
and the dealer should read the line above where it says do not re use rotor bolts.
I'll have to hear of a failure. I have a wheel off, I can take it to work and check its hardness. If it is harder than the grade 8 bolt, then we can agree the bolt weakens before the alum. threads stretch?
(SCREW 5/16-18 X 7/8 TORX pan hd., w/lockpatch (Grade 8))
.41 at Boardtracker
Old Jul 20, 2016 | 01:22 AM
bklynbob's Avatar
bklynbob
Default Diamond Engineering
Ive been using these.
Old Jul 20, 2016 | 08:18 AM
GTK's Avatar
GTK
It doesn't cost much to do the job right and no worries.
Old Jul 20, 2016 | 03:04 PM
Joe12RK's Avatar
Joe12RK
replace them with chrome ones from Harley that are correct strength
Old Jul 20, 2016 | 04:42 PM
smitty901's Avatar
smitty901
You should replace them , but many go cheap and do not. Mostly those planning on selling or trading the bike.
Maybe that why we see so many issue with used Harleys.
