ABS wheel bearings
08 Road King with ABS:
Are the F and R ABS wheel bearings a "special" HD part or can a bearing shop supply this.
Is the non-ABS side still the 6205-2RS industry standard PN?
The ABS sensor bearing is a HD item, the non ABS is a pretty standard 6205, I used ALLBALLS but other brands are aviliable
http://www.ebay.com/itm/162104397342...%3AMEBIDX%3AIT
ww.ebay.com/itm/391164277044?_trksid=p2055119.m1438.l2649&ssPageNa me=STRK%3AMEBIDX%3AIT
Now to find the elusive 9285 pulley bearing
Yeah, I've seen that, but as an aside, I bought a ABS set from Custom Chrome in the UK, which came as described in fleabay above, 1 ABS bearing, 1 ALLBALLS bearing. The ABS had the Harley part number on it!
So I don't know if they are simply bundling bearings sourced via HD.
Anywho, I think it the non abs bearing from HD (updated a few times) that mostly gives trouble.
