Harley Codes help
Old Aug 8, 2016 | 05:52 AM
Puddin2665's Avatar
Puddin2665
1st Gear
Default The Code is back
So yesterday I unplugged the ET sensor and cleaned the contacts but didn’t remove the sensor from the engine cylinder. Clear the code and rode about 50 miles with no code.When I got on it the morning @0400 to ride to work the engine light came back on and the P0118 code is back.The only difference I can think of right off the top of my head is the outside air temp was about 20 degrees cooler this morning.I picked up a new ET sensor Saturday so I guess after some of the suggested checks I will be changing it out this afternoon. Any thoughts or suggestions will beappreciated.
Old Aug 8, 2016 | 06:43 AM
Vernal's Avatar
Vernal
Did you do any of the tests I posted above?
Old Aug 8, 2016 | 06:55 AM
Puddin2665's Avatar
Puddin2665
1st Gear
No haven't yet going to try those this afternoon. Depending on how work goes.
Old Aug 15, 2016 | 04:08 PM
Puddin2665's Avatar
Puddin2665
1st Gear
Default Problem solved
Just thought I would update everyone. After not finding anything in the wiring I changed out the ET sensor yesterday. Very happy to say rode to work this morning (similar conditions as the last time I got the code) and back home with no codes.
Old Aug 16, 2016 | 09:23 AM
14GuineaPig's Avatar
14GuineaPig
Thanks for the update.
big- mike
Jul 25, 2017 09:26 AM
Orb
Exhaust System Topics
Sep 25, 2016 05:56 AM
SwiftyBKells
Nov 16, 2013 07:38 PM
ubiasylum
Sep 26, 2010 08:51 AM
jf
Apr 27, 2009 09:12 AM
