ABS or not?
Old Aug 20, 2016 | 04:24 PM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by ctwith3
So you think, or know, there have been no improvements?
I KNOW that the ABS trigger is STILL substandard to an actual tone ring for the sake of looking retro. Slower to engage and slower to disengage. I have two Harleys, one with "modern" HD ABS and one without. Harley's design is criminal; there is a NHTSA investigation into the fact that at least one version of HD's ABS fails and causes the complete loss of either the front or rear wheel braking. I also know why it fails.
Tell me what YOU know of Harley ABS.
I'm not against ABS; I believe it can be an incredible safety tool IF it's designed and executed properly. However, when a company designs a safety system (such as ABS) and makes how something "looks" one of the chief design parameters it's a compromised design. Think about it; how is it that Harley is the ONLY ABS system on the planet that uses 9 wheel ball bearings as wheel speed sensors (the heart of an ABS unit) and everyone else uses a dedicated tone ring that updates more often? Is it possible in anyone's mind that Harley has it right and all the other manufacturers have it wrong?
I'm just some guy on the internet and my opinion may or may not measure up to the one right before it or right after it. OP, do what you think is best, just understand that Harley's system is substandard to every other system out there. Use it as a tool, practice emergency stops, trying to stop in the shortest distance possible and NOT to engage it. Always keep in the back of your mind that it's possible one day you may wind up losing either the front or rear brake completely when the HCU valve corrodes and locks the pedal or lever.
Old Aug 20, 2016 | 04:46 PM
btsom's Avatar
btsom
Two primary concerns. 1. A washboard surface can make a perfectly functioning ABS totally disable your brakes. It has to do with the cycle time and the brakes being turned off by the ABS every time the wheel makes contact with the road. I grew up north of Chicago and know how to drive on snow and ice. Along with that conditioning comes the idea that my brakes won't fail on a 90 + degree summer day as they did on that washboard surface. That is an experience I will never forget. 2. Until the ABS controller is redesigned or has revised parts installed, you stand the real chance of needing to spend $800 to $1600 every 4 years to keep both brakes working. The "hydraulic lock" malfunction is real, but I have never heard of it happening to BOTH brakes at the same time...yet.
I am a hard headed old SOB and if I get killed in a braking situation, I want it to be MY fault, not that some electrons got confused and took away my brakes. If neither scenario seems very likely to you, go with what you want or can afford. ABS is not perfect yet, even less so on Harleys. Your call.
By the way,ABS has a tendency to get people to where they will just grab a handful of brake and stomp on the pedal. No problem for an ABS bike, but might you ever ride one not equipped with ABS? That habit pattern may well get you some road rash on a non ABS bike.
Old Aug 20, 2016 | 04:53 PM
Sparkee...'s Avatar
Sparkee...
I ordered my first Harley, which is my present E Glide Classic, with ABS. I had been off bikes for some years and wanted the feature on the new bike specifically for panic braking. I have tested it on dirt however I don't think I have really "used" it yet, even with some pretty hard stops on pavement. It probably did some good without my knowledge but it is still there if I need it.
Old Aug 20, 2016 | 05:29 PM
user 46092's Avatar
user 46092
My concern is that my dealer doesn't have a black arak with ABS at Has to find one. The next 2 closest dealers are 1 hour away in opposite directions from my house, and I'm not a fan of either one. The dealer I prefer to deal with will have to find me one, which will effect bargaining. Of course ABS is a good thing, but I've also heard that there are some problems out there with HD's ABS.
Old Aug 20, 2016 | 05:48 PM
Scarz's Avatar
Scarz
I won't buy another bike without ABS.
Old Aug 20, 2016 | 05:53 PM
HD_fan's Avatar
HD_fan
This. ABS has saved me a couple of times already. Don't care how experience you are, when you ride every day rain or shine ABS will pay for itself. I love riding in the rain. The harder it pours the more fun I have.
Old Aug 20, 2016 | 06:23 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Still more to it then just slamming on the brakes. Many years bikes without ABS .
Old Aug 20, 2016 | 06:29 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
No brainer. Go for it.
Old Aug 20, 2016 | 08:23 PM
Red's Avatar
Red
I'll guarantee there's not one person on this forum that can out brake ABS. Especially in uncontrolled situations which is the way we ride.
I've been riding on the road for 51 years. I'm a high mileage rider and won't ride without it. It's a tool that might save your a##.
Old Aug 20, 2016 | 09:41 PM
big papa AZ's Avatar
big papa AZ
Been riding 30 years. I would never own a bike without ABS. The Rushmore's linked and ABS brakes are great.
