Problems mounting Freedom Wings
Old May 23, 2007 | 08:56 PM
dougbk's Avatar
dougbk
Default Problems mounting Freedom Wings
I got a set of Freedom Wingshttp://www.freedom-wings.com/index.html and mounted them today, the fit on my 06 Ultra is horrible. I have seen them mounted on others and they fit the contour of the bat wing and close all the way, these don't. Anybody else had this problem?
To late to contact the manufacture so I thought I would tap into this brain trust.
Also, I know about Dragon Wings, but don't like the look, so no need to try and steer me that way.
Thanks in advance,
Doug
Old May 23, 2007 | 09:05 PM
jeepster09's Avatar
jeepster09
Default RE: Problems mounting Freedom Wings
I have them and the fitt sucks, I still like them though, they do a good job and are adjustable.
Old May 23, 2007 | 09:51 PM
HDUC1's Avatar
HDUC1
I have a set on an 05 Ultra and the fit is fine. Ireally like the way they work. Is the 06 batwing the same?
Old May 23, 2007 | 11:15 PM
GliderXXX's Avatar
GliderXXX
Depends on what your expectation is for a fit I guess. Mine don't fit 100% flush, with just a very slight gap at certain areas along the outline, but they fit well enough. I really like mine.
Old May 24, 2007 | 12:23 AM
dougbk's Avatar
dougbk
Mine won't even close to a straight up and down position they hit the forward portion of the fairing, leaving them at an angle with gaps on both ends. Maybe I expect too much
Old May 24, 2007 | 12:28 AM
CSI's Avatar
CSI
is that a good link? Not workin for me
nevermind.....worked this time around
Old May 24, 2007 | 12:32 AM
dougbk's Avatar
dougbk
The link works for me. So I dunno.
Old May 24, 2007 | 02:05 AM
Lpye's Avatar
Lpye
You adjust them before you tighten the screws. I have put on two sets with no problems. You close the with the screws slightly loose unil the fit the contour. Then tighten the scews.
Old May 24, 2007 | 02:12 AM
gman's Avatar
gman
not to steal the thread, but installed the Kury dragon wings and they went right on with no problem. work great.
Old May 24, 2007 | 10:14 AM
luckystars5's Avatar
luckystars5
I have the Freedom Wings on my 06 Ultra and the fit / appearance is great! I could not believe how much air is re-directed onto me when the wings are open. At 60 mph had to close them down a little. The install took about 10 minutes. Pull the wing away from the fairing while tightening the bolts and they will close up against the fairing almost without a gap (tiny gap at top and bottom).
Teufelhunden
Milwaukee Eight (M8)
May 22, 2017 10:16 PM
slapshot12
The Patriot Guard Riders
Dec 7, 2013 02:02 AM
klagair
Apr 13, 2006 08:52 PM
