Problem I haven't seen with rear brake switch.
Old Aug 24, 2016 | 07:35 PM
ORradtech's Avatar
ORradtech
Default Problem I haven't seen with rear brake switch.
Riding home last night a car pulled up and said my brake lights were staying on.
My first thought was that the front brake light switch had broken. When troubleshooting it this evening I decided, just for the heck of it, to pull the wires off the rear switch. The brake lights went out. Shorted the wires and got lights.
Everything I've read about the rear switch says it fails and gives no brake light. Mine appears to have failed with an internal short, leaving the light constantly on.
At least it's an easier, less expensive fix than the front switch...
Old Aug 24, 2016 | 07:37 PM
Uncle Larry's Avatar
Uncle Larry
I had one do the same thing. Quick fix.
Old Aug 24, 2016 | 08:11 PM
RANGER73's Avatar
RANGER73
It's a pressure switch. try removing it and cleaning it. When was the last time you flushed the brake fluid?
Old Aug 24, 2016 | 08:14 PM
Smokey Stover's Avatar
Smokey Stover
Year and model?, There was a recall on the 2010 touring models rear brake switch
Old Aug 24, 2016 | 08:23 PM
ORradtech's Avatar
ORradtech
Hadn't considered cleaning it. Not sure I'd trust it again. New is less than $20.
I've only had it about 17 months. Fronts been done but not the rear. Seems like a good time to do the rear...
Old Aug 24, 2016 | 08:29 PM
ORradtech's Avatar
ORradtech
07 Ultra Classic. Not really worth dealing with a dealer for this.
Old Aug 24, 2016 | 09:09 PM
REPO1's Avatar
REPO1
Mine did the same thing.
Old Aug 24, 2016 | 09:48 PM
t. sawyer's Avatar
t. sawyer
07 sg. just changed mine a mo. ago. easy, for a change.
kroozeabout.
Old Aug 27, 2016 | 09:39 PM
ORradtech's Avatar
ORradtech
Well, what a pita this is turning into.
Changed out the switch with the Accell one with no real problem. The switch itself is a larger size and needs a3/8" drive 1" socket but I have that so that's OK.
Went to flush the old fluid out and that's where the problems started. Long story short, the bleeder was stuck and rounded off. Several different types of wrenches and finally resort to vice grips. Naturally they damage the bleeder to the point it won't seal...
So, off to get a new bleeder first thing tomorrow so I can ride until the new stainless steel speed breeders I just ordered get here.
fish-r-ride
Apr 25, 2021 12:42 PM
lakedrum03
Apr 17, 2017 05:05 PM
mpaquette
Jun 16, 2012 08:58 PM
BlackFLHR
May 24, 2011 02:01 PM
95Heritage
May 27, 2007 09:46 AM
