still broke
Old Aug 31, 2016 | 02:06 PM
  #41
svarnster's Avatar
svarnster
Originally Posted by bagman1
Remember K.I.S.S! You said you've done a lot of things, but you never said you changed the filter on a 16 year old gas tank. Even though you had good pressure, you may not have the volume. If theirs crap floating in your tank (lining separation) it can be blocking filter as level or amount of crap that gets on the filter changes, then settles runs ok, than blocks again.
I have had tank off and all the fuel pump parts out , no hole in the lines, I poured fuel through the filter it flowed good. I had very minimal debris in the tank, which i cleaned out and none on the screen of the pick up. I had the same thought of it using up the fuel so to speak which was why I had the regulator changed, I guess I figured if the pressure was correct and the fuel flowed through the filter easily that the filter was ok. thank you for the help
Old Aug 31, 2016 | 02:30 PM
  #42
Tedwilliams09's Avatar
Tedwilliams09
Does it matter what gear you are in??
Old Aug 31, 2016 | 06:48 PM
  #43
svarnster's Avatar
svarnster
it normally happens after a 5 mile stretch at 60 + in 5th, then it will affect the bike at all speeds and gears. when I get it to run right after it has acted up, it becomes more constant when it does it. If I stop and try to work on it, it normally starts Idling fine then I start off and it will run great or act as if it is on 1 cylinder but even then it runs strong. but I can hear in the exhaust that it sounds muffled and not as crisp as usual,
Old Aug 31, 2016 | 06:53 PM
  #44
Tedwilliams09
Everything Says coil... once they get warm they act different.
They will light a test light but doesn't mean they are throwing enough volt to ignite fuel
Old Aug 31, 2016 | 08:00 PM
  #45
svarnster's Avatar
svarnster
I buy that, is there a way to test it, when it gets hot? I will also check and see if an 06 is compatible with my 00 if so I may be able to borrow one for an hour or so.
Old Aug 31, 2016 | 08:01 PM
  #46
Tedwilliams09
Best way is to swap one out
Old Aug 31, 2016 | 08:06 PM
  #47
svarnster's Avatar
svarnster
I just checked an the 06 is a different part # I will have to see what I can find.
Old Aug 31, 2016 | 08:31 PM
  #48
jammerx's Avatar
jammerx
I had 89 FLHS that did the same thing, I would ride for an hour and it would die. I would sit on the side of the road for 15 minutes and it would start up and run all day. It drove me crazy. Everything tested out, but in the end the coil was the culprit.
Old Aug 31, 2016 | 11:28 PM
  #49
svarnster's Avatar
svarnster
mine never dies it just acts like 1 cylinder drops out
Old Sep 2, 2016 | 11:40 PM
  #50
svarnster's Avatar
svarnster
hurricane is gone, I gotta cut up some trees, but hopefully I can go for a ride to try out a couple of the suggestions.
