Is that gap supposed to be there
Old Aug 26, 2016 | 11:47 PM
jory434's Avatar
jory434
Originally Posted by kidn1980
Jory...the retainer what do you mean...nevermind I see thank you
And I could be mistaken on manual instructions for an 06, mine is a junky *** '13 model so that's all I've worked on. That gap might be there on an 06? As far as a wobble goes an "advanced search" will blow your hair back on that subject.
Old Aug 27, 2016 | 12:58 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Ripsaw....what do you mean take a pic of backside
Was a little confusing. 180 degrees on other side. Front view..
Old Aug 27, 2016 | 07:32 AM
bagman1's Avatar
bagman1
Originally Posted by EG-2006
This diagram shows what looks like a gap, but in reality theres a slight step (shoulder) on the axle and it may just look like a gap. Again unless I could see it in person its hardto say for sure there actually is a gap. BUT for sure the lower axle cap looks like its in backwards. See hhow the diagram cap sits flush with fork bottom, now look at your picagain, its not looking right. Did you look at the bottom side and see if the word "OUT" is on the inside or outside?
Old Aug 27, 2016 | 07:50 AM
kidn1980's Avatar
kidn1980
Thank you and yes I will re-do it.
Old Aug 27, 2016 | 07:56 AM
btsom's Avatar
btsom
For an 08, the manual specifies no gap between fork/retainer and spacer.
Old Aug 27, 2016 | 10:42 AM
hdbob2006's Avatar
hdbob2006
Just looked at my '06-that's the axle 'step' showing between the fork and the spacer.Nothing wrong there. But that lower retainer sure looks backward.
Old Aug 27, 2016 | 10:45 AM
kidn1980's Avatar
kidn1980
It was backwards...fixed it thank you
Old Aug 27, 2016 | 11:06 AM
Jackie Paper
Cool. Be sure you tighten the correct nut first and then the other. (really should use a torque wrench on those)
Old Aug 27, 2016 | 08:16 PM
EG-2006's Avatar
EG-2006
Agreed about the gap-it's really a gap between the spacer and the fork. The spacer is tight against the bearing on the wheel side and against the axle shoulder on the fork side.
Old Aug 29, 2016 | 01:39 AM
sn95bullitt's Avatar
sn95bullitt
My 03 has the same space. My buddy's 05 also has the same space.
