out of fuel?
out of fuel?
'08 FLHT, some mods, 108,000 miles ( at least) Riding the other day, about 75 or so, bike running fine. All of a sudden, engine quit. No noises, no acting up, just like I shut it off. Figured fuel pump. Next morning, I pulled the pump assembly from tank. Discovered that there was only one line attached to the pump. Fished the other out of the tank, hooked it back up, installed pump, and voila! running fine again. Never heard of this happening before, so I thought I'd post this in case anybody else runs into this. Only took about 20 minutes to fix. Strange.
out of gas?
The line that had came loose is a snap-on connector. I snapped it back into place, and made sure it was secure. Bike started right up, so I rode it home. I've since put about another thousand miles on it with no problems. This post was just to maybe give somebody else an idea in case their bike just ups and quits for no apparent reason. Something else to check. Hardest part is removing the ring that holds the fuel pump in place, but even that's not too hard. Just be very careful.
A buddy and I took 1000 mile trip this past weekend. 3 hours in his bike just caught off at about 85mph on the interstate( '07 EG 50,000 mi.). We pulled the fuel line loose from the wuick disconnect and no fuel out the tank. Pulled the top off and pump is working fine with fuel going through the filter and regulator. Put it back together and it had started pumping through again. We then rode to the nearest dealer ( we had just passed one minutes before stopping) and had them re[plce the line from the regulator out and the quick disconnect, and of course the filter while they were there. It ran perfect the rest of the trip. On the way back, about 2 hours from home mine('08 RG 10k mi.) lost power briefly above 85mph twice. I slowed to 70 and made it home. I noticed it popping back when decelerating more often than normal as if it was running leaner than normal. I'm thinking it could be the same problem. I have the same parts ordered, and will let you know what I found when I get a chance to fix it later this week. Good think I have a another bike in the meantime.
Out of Gas
For what it's worth, I forgot to mention the fault codes I got. Don't remember the numbers right off, but one was the front O2 sensor reading lean, the other two were strange. One was the rear sensor reading lean, but the other was rear sensor reading rich. This is part of what prompted me to look at the fuel pump, as I had just filled the tank. No problems with the filter housing being cracked. I got that memo, and checked it out myself. I change filters every 30k or so, and inspect everything while I'm there.
