Sometimes it won't start
Old Sep 19, 2016 | 04:29 PM
08streetglyder's Avatar
08streetglyder
Stage IV
Default Sometimes it won't start
I'm new to the forum. I have a 2008 Streetglide, I've had about 4 years now. It always starts in the mornings and after its set for an hour or so. It's hasn't failed to start after a while, yet. But sometimes, like when I stop for gas or to get a quick bite to eat, it won't start. It turns over, but won't start. Sometimes it will fire like it's going to. Sometimes I can turn it off and wait 30 seconds or so and then it will start, sometimes not. But if I let it set an hour or so it's always started so far. I'm puzzled. And as always, when I have it at the dealership it never fails to kick right off. HELP
Old Sep 19, 2016 | 08:06 PM
davemc's Avatar
davemc
Welcome to the forum. Your problem could be any one of a number of things: sticky exhaust valve, coils, ignition, vapor lock (gas cap too tight?), intake leak, etc. Can you figure out if it is a fuel problem or a spark problem? Sounds like something is not making contact when it is hot.
Old Sep 19, 2016 | 08:29 PM
Eunoterpsia's Avatar
Eunoterpsia
Of course... your problem could be a multitude of issues... but if I were you... I would start with the kiss method. While cold (since it starts cold)... start the bike and while running, pull the fuel pump fuse, remove the fuel quick disconnect and check for debris. Clean out with brake fluid up inside the qd adapter at the tank and the actual line... reconnect... replace fuel pump fuse.
Personally... I'd pull the CPS and clean out the orifice... and I'd do the same for the engine temperature sensor, and clean out the orifice and the sensor as well... reattach and I clean out the electrical connectors and use electric grease before re-installation.
I know not every sensor will come up in the diag mode... but have you pulled the codes (if any).
Old Sep 19, 2016 | 08:41 PM
rocket23's Avatar
rocket23
please, for the love of god use brake cleaner...not brake fluid.
Old Sep 19, 2016 | 09:01 PM
btsom's Avatar
btsom
Have you tried varying the start procedure? Waiting for the fuel pump to finish priming when hot can cause problems, try an immediate start after turning on the ignition and see what happens. Try cracking the throttle open a bit. How fast does it crank? A hot engine has more compression for the starter to overcome. How old is the battery, have you checked the connections on the battery terminals for clean and tight? Have you ever checked the other end of each battery cable for the same, clean and tight?
Old Sep 19, 2016 | 09:08 PM
rocket23's Avatar
rocket23
I've noticed a slow start after fill up as well....albeit just once. i'll try the quick start next time, but will check the battery terminals first...might give the battery a slow charge as well...
Old Sep 19, 2016 | 09:10 PM
Eunoterpsia
Eeeks... thanks for catching that.
clydef1s
Audio Systems
May 11, 2015 10:52 AM
Scaffido
2014-2024 Touring Models
24
Sep 9, 2014 12:20 PM
filpro
Welcome Area Only
14
Mar 25, 2013 08:59 PM
Roosterboots
Jan 4, 2012 07:50 PM
77ironhead
Jun 18, 2007 01:23 PM
