New saddlebag hardware
Old Oct 6, 2016 | 03:06 AM
clackavosticus's Avatar
clackavosticus
Smile New saddlebag hardware
Just had the dealer fit the new model saddlebag retaining hardware as used in the 2017 touring models on my 2014 FLHTK while getting other work done on my bike.
The kit cost about $70AUD and they fitted it for free.
I am much happier now with the securing of my precious saddlebags - I still remember that sinking feeling when I found one of the 1/4 turn pins had come out. I will have such feelings no more. I can rest easy knowing the bags are well secured now.
By the way if you want to do the same part number for the kit is: 90201540 - its well worth the investment.
Old Oct 6, 2016 | 05:16 AM
just plain john's Avatar
just plain john
Why would you have the dealer swap out the hardware? Nothing could be simpler. I swapped out my stuff with materials from the corner hardware store for less than $10, and that's just because I used ***** instead of regular screws or it would have been even cheaper and it's just as secure as yours.
Old Oct 6, 2016 | 05:40 AM
clackavosticus
Default Reason
I just don't trust myself with a wrench doing even the simplest of jobs. In this case I'm not really sure how to properly mount the receiving threaded hardware. Sad I know....
Old Oct 6, 2016 | 05:43 AM
NELS's Avatar
NELS
It's a smart man wo knows his limitations, but I bet you excel at something else.
Old Oct 6, 2016 | 05:57 AM
just plain john
Sorry, no offense intended. To be fair, I have only the vaguest notions of the hardware, having only seen it once. On the other hand, if you can install a U nut you can change the hardware. Countless threads out there about it.
Old Oct 6, 2016 | 06:52 AM
gusotto's Avatar
gusotto
Harley had a problem with the saddlebags falling off with the old hardware that wasn't up to snuff on new bikes.
Suppose to be a recall on those saddlebag mounting hardware.
Should be free!
Old Oct 6, 2016 | 07:08 AM
Larry Davis's Avatar
Larry Davis
I think you did the right thing letting the dealer do the install. These new for 2017 bolts are special and I'm sure nothing like them are available at any hardware store.
Old Oct 6, 2016 | 07:12 AM
patrick74's Avatar
patrick74
I also had u-nuts and bolts. However I did pick up the kit and installed on my 15. The thing I like is the washer has rentention dimples in it. So as you tighten you feel it click in as you tighten. Keep's them from backing off like a lock washer would
Old Oct 6, 2016 | 07:41 AM
Farmboy666's Avatar
Farmboy666
You might not find the Harley ones in a Hardware store but that doesn't mean the bolts you can buy for $7.00 won't work. I've had them on my bike for a few years. Took about 10 min to install.
Old Oct 6, 2016 | 06:11 PM
clackavosticus
Cool Thanks
Thanks for the thought - come to think of it I think I excel at my job....needless to say there is no wrenching involved in it!
