Security ?
Old Nov 13, 2016 | 09:08 PM
RCE's Avatar
RCE
Stage I
Default Security ?
New Member from MN
Hello, Just Bought a 2015 flrtx, how do i tell if it is security enabled? no fobs or manuel when purchased, no light on dash, just starts right up, i can lock the forks though. Hard to believe no anti-theft was installed on a 2015? Can anyone help
Old Nov 13, 2016 | 09:27 PM
skid_pimp's Avatar
skid_pimp
Welcome to the forums, if you don't have a fob, and there is no blinking red light on the dash, you do not have a security system. You will still have a fork and ignition lock. Flip the cover on the ignition to the side to uncover the key slot.
Old Nov 13, 2016 | 09:30 PM
the wild hog's Avatar
the wild hog
Welcome and no fob, no security.
Old Nov 13, 2016 | 11:15 PM
critter85's Avatar
critter85
If you don't have a fob then one of two things is possible
1. The doesn't have security which is an option
2. It has been disabled and the fobs are gone
Old Nov 14, 2016 | 03:52 AM
Daytona Fat Boy's Avatar
Daytona Fat Boy
I'm guessing you're talking about a Road Glide model. The security system is a stock item on a FLTRX (Road Glide Special). It is an option on the FLTR (Road Glide). A quick way to visually tell the difference between the two models is to check whether your bike has the factory pin striping. Bigger touch screen on the radio? GPS? If not, you may have purchased a FLTR.
Old Nov 14, 2016 | 11:10 AM
dpmerrill's Avatar
dpmerrill
If your bike doesn't have the security system installed from the factory, you can still add it later if you want. $360 for the system module, and an additional $100 for the siren.
Old Nov 14, 2016 | 11:26 AM
mkguitar's Avatar
mkguitar
Originally Posted by RCE
... Hard to believe no anti-theft was installed on a 2015? ...
as above this can be an option- on many models it is packaged with cruise control and ABS.
there are base models, option packages, and premium models with more standard features- priced accordingly from H-D.
the security module can be added which will prevent the bike from running.
ABS cannot be added - the cost is prohibitive
for an audible alarm, many of us use a $6 radio shack siren rather than spend 10 x that at the dealer
anyone with security should right now learn how to set and enter the PIN from the turn signals to disarm the security should the fob not work
the owners manual should be in one of your bags- it'll help you get familiar with your new bike
Mike
Old Nov 14, 2016 | 11:39 AM
SeeJeepCrawl's Avatar
SeeJeepCrawl
Mike
+1 on this.
Check the VIN to find out exactly which model you have. From there, you should be able to find out the standard options for that model.
Old Nov 14, 2016 | 07:06 PM
Second Wind's Avatar
Second Wind
FLTRX- Road Glide
FLTRXS- Road Glide Special
Old Nov 14, 2016 | 07:10 PM
Second Wind
I paid $6.00 for my siren from Radio Shack.
Mine came with Security System but no siren. Siren is an option.
