shift linkage
Old Nov 14, 2016 | 03:10 PM
hardheaded's Avatar
hardheaded
Default shift linkage
hows the quality of the HD shift linkages ? looking at the smooth one part# 33814-98A.
Old Nov 14, 2016 | 03:54 PM
SeeJeepCrawl's Avatar
SeeJeepCrawl
For $30 more I would upgrade to:
H-D Part#: 33801-09
Old Nov 14, 2016 | 04:09 PM
just plain john's Avatar
just plain john
For about half the money I got this instead. https://www.amazon.com/Kuryakyn-1077.../dp/B0050DCC6W Looks the same. I've logged around 5k on it with zero issues.
Old Nov 14, 2016 | 04:55 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
You want good heim joints on what ever you choose.
A few years ago a forum member found a GREAT deal on some and posted pics, man we cleaned that place OUT! Great ones do not have to cost an arm and a leg.
Old Nov 14, 2016 | 05:10 PM
Jackie Paper's Avatar
Jackie Paper
Be real careful if you go to a non OEM Heim joint. They need to be loose. Most are actually quite firm. The standard OEM non Heim regular shifter is designed that way for a reason. Heim will cause all kinds of shift problems since there needs to be a little play. You need to be able to move the Heim sphere with just you thumb and pointer finger.
Old Nov 14, 2016 | 06:40 PM
cncmike's Avatar
cncmike
The smooth one you are looking at works well. It is the least expensive one with Heim joints that Harley sells. I have added mostly smooth un decorated chrome pieces. It looks good and has quality and well chromed hardware. I've had mine for at least 50,000 miles with no problems. It's not the cheapest you can find but it works as well as any and I like using factory parts.
Old Nov 14, 2016 | 08:57 PM
BackRoader's Avatar
BackRoader
They are of course top quality also.
Old Nov 15, 2016 | 07:33 AM
talkingrock's Avatar
talkingrock
Default shifter
H-D Part#: 33801-09
I went with the HD that is slotted with the bar & shield its the same shape ,looks & works fine ,either one is better than OEM
Old Nov 15, 2016 | 11:33 AM
T Man's Avatar
T Man
H-D Part#: 33801-09
I tried to get the one that has Road King written on it but apparently they aren't made by HD anymore so I got the one shown above. Very high quality as would be expected. I also added the inner primary cover and lower engine cover on the same side of the engine so I have lots of bling there now lol.
Gizmo83
Milwaukee Eight (M8)
Aug 15, 2018 09:51 PM
Ben221
Oct 14, 2017 07:44 PM
zoood
15
Apr 9, 2011 07:11 PM
Scubadog
Feb 19, 2010 07:25 PM
DaSham58
Feb 19, 2010 12:46 PM
