PC III usb map help please
Am I on the right track here? Can someone that knows more about this than me give me a
starting point to start tweaking this? I'm thinking of starting here, but I have no idea if this is where I should start
Before After
2 5 2 5
2000 14 16 11 13
2250 0 19 0 14
2500 0 16 0 13
2750 0 3 0 3
3000 0 9 07
Here's the existing MAP.
0 2 5 10 20 40 60 80 100
500 0 0 0 0 0 0 0 0 0
750 6 1 0 0 0 0 0 0 0
1000 6 7 7 10 0 0 0 0 0
1250 6 12 12 16 -7 -7 0 0 0
1500 6 13 19 19 6 -12 -2 2 5
1750 6 18 17 17 5 -5 -4 -5 -7
2000 6 14 16 19 11 -11 -10 -9 -4
2250 0 0 19 13 12 -6 -6 -3 -3
2500 0 0&
https://www.hdforums.com/m_1536754/tm.htm
I let the bike warm up, plugged in the PCIII via USB. First thing I noticed is that my Throttle at 0 (to the right of the screen) was running between 6 - 7% Note: I haven't changed anything from the
maps I received from FuelMoto and Jamie as of yet. I've read that the first thing I should do is make sure this is 0% at 0 TP. So I set this to 0 before I did anything else.
I'm making an assumption here that if my TP at 0% was running at 6-7% than that will scew what Jamie's map was supposed to do to my bike by making everything roughtly 6 - 7% richer than
the numbers in the boxes? Is my thinking correct here? At least this would sort of explain to me why I'm only getting around 35MPG when I was getting 41 prior to the PC III.
Net thing I did after setting the TP at 0 to 0 is:
I thing figured what the heck, and set my number the same as what iclick had his set when he was happy (the number he set in the post you included the link for).
Went for a quick spin and the bike ran like crap! flat spots in a couple of places, popping on decel also.
Next I set it back to the map that Jamie sent me (I included those numbers in this post earlier) but the TP is still at 0 now at 0 and not 6 to 7%.
Went for a quick spin, no flat spots at all, but she now "gurgles" a bit on decel, not quite popping. Do you folks think that just setting the one thing I changed wthout
touching any of the "cell" nubmers at varios RPM and TP's will make much of a difference? I guess what I'm asking is how badly will the 6 or7% at 0 TP impact MPG?
Thanks,
Joe
I let the bike warm up, plugged in the PCIII via USB. First thing I noticed is that my Throttle at 0 (to the right of the screen) was running between 6 - 7% Note: I haven't changed anything from the maps I received from FuelMoto and Jamie as of yet. I've read that the first thing I should do is make sure this is 0% at 0 TP. So I set this to 0 before I did anything else.
I would try leanng the cruise range step-by-step. Start by cutting the values in half in the range mentioned above, then if you don't see any performance problems cut it again, until you get to "0", at which point I would stop. Jamie at Fuel Moto told me that "0" in that range is around 14.0-14.2:1 A/F, which to me is about right for optimum mileage.
I downloaded the entire manual today and there's a nice tutorial on the website on resetting the
throttle. It's exactly as you describe, although the manul says you can do the 100% with a 9v and the ignition on??? Would I see the numbers you are talking about with the Battery method or should I actually rev it briefly to 100 TP?
I changed all of my numbers for 5 10 and I believe 20, I know I didn't touch the 30. But as I said, I put it back to what Jamie gave me. The flat spot was brief, almost like a cylinder wasn't fireing than it grabed and pulled pretty hard. My starting numbers I think were higher than yours were from Jamie though???
On theheat side, this is the reasonI got the PCIII in the first place. Brief story:this is my first HD, been riding cruiser for years though last scoot was a Yamaha air cooled 1600cc silverado. The 05 Ultra ran so hot I thought therewas something wrong. Dealer said, nope, all is fine. I checked the temp with a candy thermometer once warmed up properly and the oil was cooking at 270+. I put in HD syn at my 5K with the Stage 1 (AC and SEII slip ons with the HDmap). No change in temp.I thengot the PCIII last year, Mobil 1 VTwin in two holes and Redline Heavy Shock in thetranny. Not sure what the temp is now, but it feels much cooler to ride than before.
Tonight, my plans will be to check the 100% and reset 0 and 100 if required. Then I'll cut the
5 and 10% TP's in half between 1750 and 3000 RPM and see what that does.
Thanks,
Joe
Again, mine works like this and yours should too, but like people all bikes are different. Let us know how your experiments go.
If you want to look at the tutorial, they are on the fuelmotousa website, under FAQ 1/2 way down the page there's one for resetting the open and closed TP.
Joe
