Compression release question
Old Jan 11, 2017 | 06:30 PM
RFC1962's Avatar
RFC1962
Default Compression release question
Having compression release ports put in my 09 96 cylinder heads. I would really like to put the ACR type that the newer 103's use. Is that an option on a 96 head or is the placement in the combustion chamber a problem or performance limitation. I know the 103 has a slight slot milled into the combustion chamber to position the solenoid in the middle of the head. Thanks in advance for any info... Mike
Old Jan 11, 2017 | 06:53 PM
EdwardK's Avatar
EdwardK
I don't know all the details but my indy machined my heads and put the ACR's on my 08 when he upgraded it to a 103. There was an additional wiring harness he had to get as well as going into the ECM to turn them on.
Old Jan 11, 2017 | 06:56 PM
rkoivisto's Avatar
rkoivisto
Default CR's
There are plenty of people that will bore an 09 head for CR's.
You will have to turn them on with a dealer flash or some type of tuner.
Old Jan 11, 2017 | 07:06 PM
RFC1962's Avatar
RFC1962
Lot of guys put the manual ones on that you have to reach down and push the button in. If I can I'd like to just put the electric solenoids on. You can just wire into the starter solenoid circuit I would think instead of programming the ECM. I have a DynoJet PowerVision tuner so that may be an option to do within that. I just wasn't sure if the 96 head combustion chamber shape is the same a the 103 and you could put the release valves inboard of the head instead of out by the spark plug.
Old Jan 11, 2017 | 07:16 PM
Uncle Larry's Avatar
Uncle Larry
Wire them through the "Start" switch"
Old Jan 11, 2017 | 09:05 PM
IKnowNot's Avatar
IKnowNot
Hardest thing about it was finding a dealer with the tool (Screamin’ Eagle Automatic Compression
Release Tool, part # 94648-08) that would do it (and I trusted.)
Wired it up with the Harley harness ( 70623-06 or 70623-08, depending on application.)
Had the dealer freshen up the heads while they were at it, about $500 total, I did the removal and install of the the heads.
The PV can turn on the ACRs.
Other options; manual releases (cheaper) or Easy Start cams.
Old Jan 12, 2017 | 08:35 AM
todd-67's Avatar
todd-67
I just got some 103 take offs and the harness for my 107 build. The harness was like $60 bucks or so. Your heads can be machined if the shop has the jig for it. Not all do when I was asking around. The jig is like $900 so I was told and not a lot of people ask for it. They use the manuals and there were only a few years where they were able to be added.
Old Jan 12, 2017 | 08:43 AM
Deckman's Avatar
Deckman
I had auto ACR's put on my 107 big bore with stock 96 heads. Need a wire harness installed to start switch and they work great. Easy starts.
Old Jan 12, 2017 | 06:28 PM
rkoivisto's Avatar
rkoivisto
Default Try these guys
www.danvanceracing.com
If I were going to send heads out to get ACR's, I would have them ported at the same time.
It's $250 for these guys to drill ACR's and $400 for a street port. They may have 103 ported heads ready that they would swap out so you wouldn't have to wait too long on them.
Old Jan 12, 2017 | 06:54 PM
farmboy555's Avatar
farmboy555
I have the maunual ones on one of my bikes, just have to push them in before cranking it over
