Compensator Replacement
Appreciate it!
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
http://www.harley-davidson.com/store...18-40100061--1
Appreciate it!
B Bop
A politician is a fellow who will lay down your life for his country.
So if you are replacing the original comp you should be using HD part number 40100061 which comes with the rotor and new spring-pak.
(No, you don't need to replace stator)
If comp has already been replaced with an SE you shouldn’t need new rotor, it would already have one.
I would not grind the inner primary (I should say I would not do it again)
Any time savings is lost trying to clean up those shavings.
Now you may have enough freeplay in your chain to get away with not removing the clutch.
But I would not risk tweaking the chain; take the clutch off with the comp!
There is a reason both HD and Baker say to remove them together.
Anyway, with those miles you should take the opportunity to check the inner primary bearing while it is apart.
Good Luck.
