1) Stage 1 after your first 1,000 - (I rode 500 the first 2 days and did it then) - Make it Sound Better - Run Better - Run Cooler
2) Replace that OEM Seat (I went with a HD Sundowner - have had them on my last few Putts with great results - done a few Iron Butts)
3) Handlebars (I went with Wild 1 WO513 Mini Apes)
4) Hwy Pegs\Boards
5) Backrest
6) Summer Heat be a comin soon - Recommend Amsoil & RJ's Orig. Heat Shield (they work Great)
I took the rest of the week off so I should hit that 1000 mile mark pretty quick. What is involved with a stage 1. Is that an air intake, pipes, PCIII upgrade?
When you guys upgraded pipes did you go to true duals or just slip ons? I dont want to go to loud as I love having my tunes. This bike is awsome.
Yes stage1 is AC, Sert, PCIII, and the like and some slip ons.
I like to go through the school of lets spend more money. Had stock pipes, went with TD's and Rush Mufflers. I know have the Bassani Road Rage on it's way from California to PA via 3 day air. I have Monday off and i want to put it on ASAP.
Biggzed.....which Corbin do you have there?
I have the identical bike.
Was thinking the Sundowner Solo then add the pass pilion when Mama rides along.
Want some more cush for the tush.....mine included!!
Would really like to find a dealer with one to try it on first before I buy!
My Harley bucks are accumulating rather nicely!!
Are you guys changing just the aircleaner or the airintake itself?
Air Cleaner and the back plate. An Big sucker, and the K&N kit come with everything needed. There's a recent thread that asks which one K&N or Big Sucker.
EDIT: Link for you. https://www.hdforums.com/m_586772/tm.htm
Parts # for WG bars is #56079-93T, also need 1 clamp # 9990W. Also I would suggest a couple of the cable ties that hold wiring to bars. While I didn't break one they sure seemed looser after install and will probably replace as they SHOULD be cheap!
