Hard down shifting.
Old Feb 25, 2017 | 03:15 PM
TSheff's Avatar
TSheff
What Year?
Is there play in the linkage - shift arm on transmission?
Do you use a heel shifter? If so double check shift arm for spline wear?
Clutch adjustment OK - Did you re-adjust it?
Primary adjustment?
Shift Pawl - is there the same feel/movement forward and back?
I've had the issue and the 3 things I mentioned corrected it.
Old Feb 25, 2017 | 04:03 PM
twistedcherokee's Avatar
twistedcherokee
I think what happened is the big spring on the shifter pawl is loosened up a bit. Not sure if adjusting it is just a bandaid where stitches are needed, but will try that. But there is no play in one direction, so it is not equal like it is supposed to be. Going to pull the shift drum & inspect that & the forks. Being a 99 with 120K miles, pieces have a right to be worn. Maybe it's time for a 6spd upgrade. Revtech has them for around 500.00. Temptations. Definitely can't afford a Baker.
Toby
Old Feb 25, 2017 | 04:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the shift lever has more free play in one direction, it most likely means that the shifter pawl needs to be adjusted.
120k is nothing for a five speed transmission, don`t get your wallet out yet...
Old Feb 25, 2017 | 06:48 PM
TSheff's Avatar
TSheff
Agree - Adjust it and ride it before you spend the $$$ unless you just want to spend the money. Doesn't sound like you have the money (I understand that) or you would go straight to BAKER.
Old Feb 26, 2017 | 05:08 PM
FXD_noob's Avatar
FXD_noob
Originally Posted by bad tappets
As other have said, check clutch adjustment first. If clutch ok, put bike on a jack, remove linkage and try shifting with some vice grips in the shift shaft (careful not to strip the splines). Rotate rear wheel by hand a bit. This will eliminate any linkage issues as the cause. You should be able tell at that point whether it's a linkage or tranny issue.
SO If the rear wheel is off the ground and you start rotating it by hand, should you be able to shift into all gears? Because I can't on my Dyna. Guess it's a transmission issue then.
Old Feb 27, 2017 | 07:33 AM
twistedcherokee
Going to adjust the pawl & try it. I don't have the money to even go to the Revtech, so either the adjustment will work or I will pull the shift barrel & forks out & inspect them. I am hopeful that adjusting it will work since it is tight one direction & has play in the other. I have noticed that sometimes when I am getting on it that it does not always go up into the next gear & neutrals out on me. So it makes sense about the pawl. Been a little under the weather, so I have not spent a lot of time on it. I am about ready to go to the Dr to get this cleared up, what ever it is.
Toby
Old Mar 1, 2017 | 05:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You have over 700 posts and you don`t know it is poor form to hijack someone else`s thread?
We are trying to help the OP here, don`t make it confusing, start your own thread.
Old Mar 1, 2017 | 05:20 PM
TriGeezer's Avatar
TriGeezer
Lighten up Dan. It seemed like a legitimate question to me, and in the context of the thread...particularly from someone that English may not be their primary language::
Old Mar 6, 2017 | 09:50 PM
twistedcherokee
Good news, I adjusted the pawl & put it back together. Rode it just a little ways, shifted good. Will ride it to work tomorrow & see if when it gets warm it still works good. Thanks for all the reply's.
Toby
Old Mar 6, 2017 | 10:09 PM
TSheff's Avatar
TSheff
Good deal.
