What I like about it is that the receiver and most of the wiring will be inside the fairing with only the interface outside. I have also found a rain cover on Ebay for that.
I'm fairly certain I won't be able to use the touchscreen with gloves on but thats ok as I only listen to 4-5 stations and won't mind having to stop if I want to change. Guess I could cut the tip out of one glove or go fingerless.
I am also wondering where to mount the antenna, manual says mount to sheet metal and to contact a experienced installer if you plan on mounting to plastic or fiberglass. IIRK some of the older radios wanted as much tin around the antenna as possible for reception.
Any of you guy's using this or any of the other add on units?
You could buy the antenna mount from Harley and mount it inside the fairing. It looks very similar to the antenna that comes with the HD XM radio. Mine worked great inside the fairing. I think the mount is about $24...
Not sure which bracket you mention.
Do you know the part #
Many years ago a friend had a satellite radio receiver that played through whichever FM frequency he selected on his AM/FM receiver.
One night he gathered a bunch of other guys with FM radios around his bike. They all put their radios on the correct FM frequency and blared XM.
When I had my 2013 RGU, I just bought a cheap XM receiver and connected it to power via USB to the power port in my tour pak. I then ran an aux cable from the tour pack, along the top of the frame and under the tank, then finally up to the aux port of my HK radio. In parallel with the aux cable, I also ran the XM antenna, and mounted the XM antenna on top of the HK radio in the fairing. I used some double-sided 3M tape to ensure it stayed put. I never had any reception issues.
Sure, I couldn't change the XM channel while in motion, but I could change it whenever I stopped. No big deal to me.
