So I'm having a small hicup with the bike(07 flhp)- when the front brake is pulled there is no brake light, but when the rear brake is applied there is a brake light.
However- if I try to use both the front and the rear brake at the same time- the right blinker activates.
I'm guessing it's a pinched wire somewhere- but I'd like a second opinion or two.
The front and right blinker switches are in the right side handle bar switch pack. I would start there. Start with unscrewing caement and examine the wires. Good luck
