Brake Lights
Old Oct 20, 2006 | 02:31 PM
Morgaja7's Avatar
Morgaja7
6th Gear
Default Brake Lights
I have a problem with my rear brake light not lighting when I press my rear foot brake but it lights up when I press my rear hand brake. Anyone have any ideas to what may be the problem.
Thanks,
Jack
[IMG]local://upfiles/19319/2EBC32276FC3406E89DCF92764371F1D.jpg[/IMG]
Old Oct 20, 2006 | 02:37 PM
gconklin's Avatar
gconklin
Default RE: Brake Lights
My guess would be the problem being at the foot brake assembly. Look down at the foot brake master cylinder and you should see a wire running from it. Check its connection, look for bad contacts, broken/warn wire or insulation, etc. Perhaps its the trigger itself though which would probably require a new part.
(sorry for the lack of technical jargon)
Old Oct 20, 2006 | 02:41 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Unless you have done some serious replumbing of the brake lines there is no rear hand brake on any bike that I'm aware of (outside of the auto balance setup on some BMW's). The brake lever on the right had grip only operates the front caliper, while the foot pedel operates the rear brake. If you have a problem with the pedel use a VOM meter on it to see if its operting properly. If not replace it.
I believe its just a shorting switch, so you can also turn the ignition on and use a paper clip or something to short the wires to see if the light turns on, if it does its a good bet the switch is toast.
Old Oct 20, 2006 | 02:52 PM
Morgaja7's Avatar
Morgaja7
6th Gear
You are right! The rear brake light does not light up when I press the rear foot brake but does light when I press the front hand brake. I will check for lose wires and test the switch.
Thanks,
[IMG]local://upfiles/19319/132374EC1E6C456BA6E0C190CCD3FAD8.jpg[/IMG]
Old Oct 20, 2006 | 08:16 PM
Nice looking Springer you got there. [sm=biker2.gif]
Old Oct 20, 2006 | 09:18 PM
nikonf8's Avatar
nikonf8
this may sound stupid but did you check the bulb it may be out
Old Oct 20, 2006 | 10:28 PM
ORIGINAL: nikonf8
I think you missed the part where he said "The rear brake light does not light up when I press the rear foot brake but does light when I press the front hand brake."
Old Oct 23, 2006 | 12:06 PM
Morgaja7's Avatar
Morgaja7
6th Gear
Thanks,
I just put axle chrome covers and master cylinder chrome covers on this weekend. I like the bigger rear wheel on your '07 softail. That is a big improvement this year.
[IMG]local://upfiles/19319/068C5C7F76D44B548CDF1E1244DAB151.jpg[/IMG]
Old Oct 23, 2006 | 01:30 PM
ORIGINAL: Morgaja7
Thanks,
Nice bike you have there.
But did you figure out the brake light problem?
It wouldn't do to have some dumb cager ram you in the rear because he didn't know you were stopping.
Old Oct 23, 2006 | 03:21 PM
Morgaja7's Avatar
Morgaja7
6th Gear
Still trying to find the problem. I think it might be the switch to the rear foot brake. The brake light works when my front brake is pressed.
[IMG]local://upfiles/19319/EF9F466FA4BA4A79B8FB3E2FEA682D97.jpg[/IMG]
