Question About Bagger Wobble
Old Mar 13, 2017 | 07:57 PM
sel53's Avatar
sel53
Originally Posted by kojak
Were your handlebars shaking violently till you slowed down?
It stopped as soon as I exited the turn and went straight. I didn't slow much in the turn because I didn't want braking making it worse.
I need to go back and look at what exactly the road does, because I've never really encountered a bump like that before either. I think it kind of threw the rear end up, rather than slamming it. I've certainly never felt any instability on this bike at 50mph.
Old Mar 13, 2017 | 08:08 PM
16X9 Shooter's Avatar
16X9 Shooter
Youtube vid shows "rear steering". I put a Ride Str8 on a long time ago (think they are no longer in business)....it helped.
Old Mar 13, 2017 | 08:10 PM
Keithhu's Avatar
Keithhu
Originally Posted by 16X9 Shooter
https://www.youtube.com/watch?v=Gmw6QppXnEY
********, its a way older bike with a different frame, mounts, etc. Not comparable.
Old Mar 14, 2017 | 02:02 AM
grbrown's Avatar
grbrown
Cool
Originally Posted by sel53
Thanks, G, I've read your fine expose a few times over the years.
The thing I found unusual, compared to any wobble I've experienced before, was the vertical motion. I guess it could be because the bump threw it up hard enough to start with, and that exacerbated the wobble while the vertical motion damped (pogo from the bump, wobble because I was in a turn tweeking the rubber mounts).
I take it you still like the true-track the best?
The vertical motion may be the poor rear shocks. Some while ago a member posted how he was following another rider on a Harley dresser, who hit a large pothole. The rear wheel came off the ground with the shocks completely compressed and when the bike came back to earth the rider lost control. That is an extreme case, however stock Harley shocks have lousy damping and a bump or big dip can do as you describe.
So having installed your T-T kit (I haven't tried any others) I suggest you seriously consider new quality shocks. You will find we can help you in all manner of interesting ways to spend your pocket money!
Old Mar 14, 2017 | 02:06 AM
grbrown's Avatar
grbrown
Keith, while it is true they have different frames they have similar rubber-mount systems, the problem has not been totally done away with - which is one reason why I wrote my thread, linked in post #4.
Old Mar 14, 2017 | 04:43 AM
Keithhu's Avatar
Keithhu
I dont disagree with you, but what is shown in that video is simply not a characteristic of an 09+ bike.
If you are experiencing something like that on an 09+ bike, there is a repair that is needed.
Old Mar 15, 2017 | 06:07 PM
Keithhu's Avatar
Keithhu
OK, I hereby publicly and formally apologize for calling 16X9 Shooter a ********.
Old Mar 15, 2017 | 06:28 PM
EdwardK's Avatar
EdwardK
I have an 08 RKC and a 13 Limited that I jump back and forth on all the time. The new frame definitely helped but didn't totally eliminate it. I have had a similar issue on the same high speed sweeping curve going home on my commute but it's usually only happens at 70 mph or over. The 08, extremely noticeable. The 13, not so much but it is still there and exaggerated when a bump is hit while in the turn. Under 50 it's none existent on either bike.
You did perfect by not over reacting and just maintained speed and rode it out. I think the people that have had accidents panicked when it happened. The last thing you want to do is grab a handful of brake. I ride through it on the 08 all the time.
I do agree with everyone here to spend some time checking tire wear, tire pressure, shock pressure, etc... If everything checks ok and it happens again that drastically, I'd have an indy look at it just to be sure.
The best thing is you now know what it is, what it feels like, and how to carefully ride through it without any panic reaction if it happens again.
Good luck!
Old Mar 15, 2017 | 06:55 PM
Sc0-'s Avatar
Sc0-
When my bike was stock i rode through a wobble and crossed 4 Lanes of traffic until it was back under control... was lucky!
Guess the only thing left is to change out the swingarm inserts or to install solid rear mounts for the swingarm bolt. Or might be cheaper just slow down... Already running the GlidePro rear mount setup and Alloy Art rear stabilizer.
Old Jul 9, 2020 | 01:25 AM
Peter Quinn's Avatar
Peter Quinn
I've had two Rushmore Street Glides that wobbled at very high cornering speeds and one that was rock solid.
Changed up to a new M8 in 2017 and tried everything to get it to behave.Ripped the back end apart and took the swing arm off. As reported before,Harley made the swing arm shaft undersized! Spherical bearing fitment is critical as only the fit on the shaft keeps them aligned.I built up the shaft and machined to a tight press fit.
Added two 1/8 x 2" stainless washers and squished them between the swing arm and the rubber. Going great this whole year. Just love this bike with full Stage111.Now nobody stays with me on the twisties or sweeps.😃
