clutch cable
Old Mar 21, 2017 | 07:56 PM
twistedcherokee's Avatar
twistedcherokee
Default clutch cable
Well another clutch cable bit the dust. Thinking about going to the dealer, these aftermarket ones I have gotten don't last. Guess you get what you pay for. Is Barrett a good cable?
Toby
Old Mar 21, 2017 | 08:56 PM
Talldog's Avatar
Talldog
Go with Magnum Shielding...Good quality cables.
Old Mar 22, 2017 | 04:10 AM
mkguitar's Avatar
mkguitar
Barnett is the first name in clutches
I paid $65 for +4" recently
what kind of trouble do you keep having?- one of my clutch cables is 64 years old.
as long as the clutch mechanism is working properly and the cable is lubed/teflon lined, should last for a long long time
Mike
Old Mar 22, 2017 | 07:32 AM
twistedcherokee
Keeps snapping off the ends (original with 100K & the second with 20K). The second one was an off the wall cheap off of amazon. But I ride in the rain, cold & hot. Plus I don't think this last one was teflon coated. Will try a Barrett. Thanks
Toby
Old Mar 22, 2017 | 07:42 AM
Buckinfitch's Avatar
Buckinfitch
I went with the Magnum Black Pearls when I swapped out my bars (mini-apes) ... great high quality cables, getchusome !
Old Mar 22, 2017 | 08:02 AM
diggerv's Avatar
diggerv
+ One...
Old Mar 22, 2017 | 04:46 PM
Pascal1340's Avatar
Pascal1340
I had a problem on my 2013 FLHTK. I had always to fasten the clutch cable and the discs were burned at 27'500 km !
I changed for a Barnett clutch kit and a Barnett cable.
They told me the problem by the Harley cable is known and comes from the collapsing of the cable collapsing. They told me it will never arrive again with their cable.
Let's see... the cable was number 101-30-10046 for an original length
Old Mar 22, 2017 | 09:47 PM
ricktherocket's Avatar
ricktherocket
Barnett makes vey good cables, never a problem with any I've ran.
Old Mar 22, 2017 | 10:05 PM
Campy Roadie's Avatar
Campy Roadie
Toby,
Why not Craigslist another stock one. They're cheap with all the ape hanger conversions. 10 or 15 bucks is the norm. Stock cables last a long time.
Old Mar 23, 2017 | 01:37 AM
Guntoter's Avatar
Guntoter
Cables need lubed every year (unless the coated ones, but I would still lube with spray silicone) or problems can occur. I have Magnum Shielding also and are outstanding cables. But they must be lubed with spray silicone when you install and again after using them a little while, especially the clutch cable.
