rear shock length
Old Mar 22, 2017 | 08:53 PM
checkers's Avatar
checkers
Originally Posted by skratch
the customs, street glides, lows etc. come with 12'' shocks while the standard touring models are 13'' shocks.
Ding Ding, we have a winner. The RK Custom's were basically a Street Glide with a windshield, 12" air shocks were standard.
Old Mar 22, 2017 | 08:59 PM
checkers's Avatar
checkers
Originally Posted by Bodacious MC
Does switching from 12" to 13" rear shocks require the drive belt to be readjusted?
Some say it does, I say it doesn't and that is from 3 FL's that I have extensive miles on them with shocks swapped up or down 1". I am running my 11 RK with 12" hand hand adjustable right now, belt adjustment was not needed. The actual change in the ride rise/lower is only about 5/8" with a 1 " shock change.
Old Mar 23, 2017 | 05:43 AM
grbrown's Avatar
grbrown
Wink
Whenever I've changed things such as shocks I back off the belt. Does it NEED to be adjusted? The least you should do is to check belt tension and adjust if necessary.
Old Mar 23, 2017 | 09:33 AM
Roadflyer's Avatar
Roadflyer
My 05 RK custom came with 12's from the factory.
If you are buying shocks to improve the ride, then buy 13's.
I have progressive 444 13.5" on the bike now.
Sorry, I can't give a ride report, I just did the Progressives over the winter.
The 13.5" required moving the mufflers a little bit, The 13" will bolt on without mods.
gsb8858
Mar 9, 2021 04:41 AM
chilidipper
Jan 4, 2018 11:50 PM
Doc4545
Sep 23, 2009 12:53 PM
Sal C
May 5, 2009 12:05 AM
twiceretired
Dec 2, 2007 09:29 AM
