Lifter problem?
Old Mar 25, 2017 | 03:19 PM
Tjones40's Avatar
Tjones40
Stage II
Default Lifter problem?
I have a 2016 street glide special with 400 miles, I rebuilt the whole top end with 110 jugs tman heads with v&h pro pipe. I have a ticking noise is in my the valve cover. Yes it's timed right and no the valves are not hitting the pistons. I rode the bike a few miles and the ticking goes away and comes back, what are the odds I have bad lifter.
I ground down the webbing in the covers and there is no sign of the springs or push rods are hitting anywhere that's why I think it's a lifter. Any thoughts?
Old Mar 25, 2017 | 03:57 PM
PeteF's Avatar
PeteF
Generally, Harley lifters bleed down quickly. If it ticks when you first start it and it goes away, then according to Harley, it's normal even after the bike has been ridden and warmed up. Another thing to check, especially after the bike is hot, is the sound of gear lash, which sounds like lifter noise. Check this by riding the bike for 20 minutes or so to make sure it's good and hot. While idling in neutral, pull in the clutch and see if the noise stops. If it does then it's gear lash, and that's also normal according to Harley.
Old Mar 25, 2017 | 04:03 PM
ROCKOUT Rocker Products
Sponsor
Take a look around my website (in my sig below)... you might find it interesting
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 25, 2017 | 05:25 PM
Campy Roadie's Avatar
Campy Roadie
What lifters did you use?
Old Mar 25, 2017 | 05:57 PM
Tjones40's Avatar
Tjones40
Stage II
Stock lifters, with adjustable push rods. The rear cylinder the rods are set correctly but if I try to set the front it holds open the intake valve and blows it through the air filter. If I back the fronts off a couple flats then it starts and runs but I still get the ticking, it doesn't tick on start up its after I give it throttle it starts to tick
Old Mar 25, 2017 | 06:22 PM
liquidr1's Avatar
liquidr1
2 things, buy the rockout inserts, they work. Ditch the stock lifters.
Old Mar 26, 2017 | 12:25 AM
Guntoter's Avatar
Guntoter
Make sure you dont have an exhaust leak. Best way to tell is using a lighter used to light a stove (has an extended shaft) and hold it near the exhaust ports and see if the flame moves or blows out.
Old Mar 26, 2017 | 12:16 PM
nhrider1's Avatar
nhrider1
Sure sounds like a bad lifter. I wouldn't risk running stock lifters in that engine. They are questionable at best. Replace them with a good set of aftermarket lifters (S&S or similar).
Old Mar 26, 2017 | 12:26 PM
Campy Roadie
Stock lifters
There ya go.
pop48
Engine Mechanical Topics
Sep 22, 2014 06:50 PM
timberwolfz28
Jun 10, 2014 08:29 PM
craiger62
Aug 30, 2012 12:27 PM
Gaelicdog
Exhaust System Topics
18
Dec 7, 2010 04:04 PM
scooter10572
Jun 7, 2008 02:46 PM
