Noisy motor
Old Mar 31, 2017 | 12:59 PM
paco12's Avatar
paco12
Default Noisy motor
Just picked up a 2006 road king with 11,500 miles changed all fluids running Harley 20/50 in motor ,,anyway curious sounds like noisy valves I thought I read somewhere these were self adjusting,do ya think if I went to Amsoil 20/50 would quiet the motor
Old Mar 31, 2017 | 01:24 PM
ROCKOUT Rocker Products
Sponsor
Have a look around my website, you might find it interesting
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 31, 2017 | 01:43 PM
Markymannn's Avatar
Markymannn
Neil, seriously, you worry too much. 88's are pretty bullet-proof. Just ride. They make all kinds of noises
Old Mar 31, 2017 | 02:02 PM
Tired's Avatar
Tired
Probably not the valves but the valve train. Fairly common situation. Syn oil will tend to make it worse.
You could do lot's of things to quieten it down some like new lifters, adjustable p-rods providing more preload, certain rocker shaft locking devices, etc.
Or you could just ride it and not worry about it.
Old Mar 31, 2017 | 04:24 PM
t. sawyer's Avatar
t. sawyer
can't say it will help yours, but I started running seafoam in the gas and the top sounds much better. can't say why, just know what I know. will not argue the point.
kroozeabout.
Old Mar 31, 2017 | 07:53 PM
Tracker1's Avatar
Tracker1
My 01 RK makes a lot of noise on top but so did my old shovel heads. I always used adjustable push rods but I haven't put them in my RK yet. I just make sure I get a good adjustment on them and leave it. They will always make noise unless you throw a lot of money at it and that might not even fix it. When it's hot out they really clatter, that's a Harley. Just enjoy the ride.
Old Mar 31, 2017 | 07:58 PM
Campy Roadie's Avatar
Campy Roadie
I'd check the spring loaded cam chain tensioners. They're 11 years old; yeah not many miles but that really doesn't mean anything. Drop the exhaust, pull the cam cover and at least look.
Sooner than later.
Old Mar 31, 2017 | 09:28 PM
Kburgad's Avatar
Kburgad
Drop some cams in, rockouts and pushrods. She will quiet down and haul a××.
Old Apr 1, 2017 | 07:22 AM
rossman's Avatar
rossman
I rode my 08 RK to FL from CA a few weeks ago. It turned 80k on the way home. Out there I decided to have fluids changed at a reputable speed shop. Tech called with concern for noise out of the primary. I gave the go ahead and he replaced the compensator which was making to racket. Needless to say HD has no replacement in kind but offer a Screaming Eagle kit. Problem solved with wallet.
Old Apr 1, 2017 | 08:39 AM
EdwardK's Avatar
EdwardK
You need a good set off pipes so that you can't hear the engine anymore. That will fix it. Good set of ear buds in the helmet works good too.
As mentioned. A little sewing machine noise or ticking from the valve train is normal. Ride the crap out of it.
After you have put some miles on it, you will get used to the "normal' sounds and then be able to tell if the noise is getting new. You also need to remember that the sounds carry different based on many factors. Road surface, wind, traffic around you, helmet on or off, windshield on or off, etc. So sometimes what you think is a new noise is something that has been there all along, just different circumstances.
Also as mentioned, regular oil is normally quieter than synthetic. Give and take.
Enjoy the new ride!!!
Cabocarl
Sep 9, 2013 10:08 PM
sloroller
Exhaust System Topics
Oct 11, 2011 07:26 PM
neonhomer
133
Jul 12, 2010 12:42 AM
roadkinglobo
May 15, 2010 05:54 AM
JC in Colorado
Mar 17, 2010 09:57 PM
