Ok so installed 100" S&S big bore kit , jugs and pistons On my 88" carb engine and now have ticking from front cyl. Sounds like valve train,rocker? Was able to turn pushrods when finished with bolting head on... any ideas? Thanks kevin
They are a light press fit. Very easy install.
What cams are you running? Some are noisier than others. Also, if you are using aftermarket cams with stock pushrods, the preload on the lifters may not be set deep enough and that may be where the noise is coming from.
Do the inserts still allow bolts to fit in rocker shafts? To hold them in place?
The same bolts that hold down the rocker supports draw the Rockout inserts down into the hole, filling the gap and locking the shaft in place.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
