wheel?
Old Apr 17, 2017 | 07:04 PM
hammer232323's Avatar
hammer232323
5th Gear
Default wheel?
Hi kinda new here. Looking for advice on where i can get a wheel for the back of my 06 Electra glide. I have a spoke wheel on front and rear. I have 4 broken spokes in the rear want to change the rear wheel to a mag or a factory wheel! Anyone know where i can get a wheel at a good price i don't need a $1200 wheel that cant be seen with the bags. THANKS FOR THE HELP!
Old Apr 17, 2017 | 07:06 PM
kel03's Avatar
kel03
Welcome to the forums, from Ontario Canada. Check the for sale ads here or Ebay.
Old Apr 17, 2017 | 07:18 PM
hammer232323
5th Gear
I did look there did not find anything that was a deal worth looking into. Thanks where do all the stock wheels go when people get new ones? I'm starting to think there is a guy with a garage full of used wheels......LOL i need to find that guy.
Old Apr 17, 2017 | 07:28 PM
tehan2's Avatar
tehan2
You could just pull the wheel, remove the tire and relace the wheel... 4 spokes would cost you less than $20 and a few hours of your time
or pay a shop to do it and you'd be done for $200ish
Old Apr 18, 2017 | 04:08 AM
grbrown's Avatar
grbrown
These things are not hanging around by the truck-load, however a little patience will get you a replacement before long. Check an on-line parts website for part numbers, which will also give you a clue on the model years to look out for. Look out for #43402-00, which was introduced 2000 and use up until around 2007/8.
Old Apr 18, 2017 | 08:22 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Local swap meets, Craigslist, eBay, etc. personally, I prefer swap meets. You can find good used wheels for ~$200 and less. Sometimes a whole lot less.
Old Apr 18, 2017 | 10:24 AM
Max Headflow's Avatar
Max Headflow
One of the things to note is that if the laced wheel has started braking spokes, it was probably run with the spokes loose for some time.. In that case all spokes should be replaced... While Buchanan is the best (especially for custom wheel sizes), Drag specialties Stainless spokes work fine for standard replacement stuff.
h2otoad
Aug 12, 2021 01:13 PM
Wizard1
Wheels/Tires
Nov 23, 2012 11:03 AM
kidney_bean
Wheels/Tires
Aug 2, 2012 09:24 PM
fxrfrank
Wheels/Tires
Feb 29, 2012 10:41 AM
metal_mike
Sep 10, 2007 08:48 PM
