What should I have done differently?
.... I'm all about 'learning. I know there are lots of 'almost' bad accidents and those who have a lot more experience riding than I have. Just wondering if/what I did that maybe I should have done differently to avoid glancing off the barrier to begin with?
I can only pray that I would have the same reaction in that short a time span. The "learning" is for me, andthe only thingI can think of is the speed. It will make me slow down for a while but having brothers that are DOT engineers I usually travel those ramps at the speeds they have told me they are designed for, plus a little for the "leaning" factor. Thanks for posting, its a good reminder.
Arvid
What with the double curve high up in the air and the second one sharper.
My thinking would be that no matter how familiar you may be with the curve,
Being dark as you say, I would have approached it more slowly.
It may have come from a dump truck or even someones pickup.
I guess consider your self lucky that the thin gravel didn't extend farther or that
it wasn't ice.
But happy to hear you made it with minimal damage.
heading to work last week I'm on an on-ramp traveling about 55mph and banking to the left. This on-ramp goes over a 4 lane highway about 20ft below. The on-ramp is kinda a double-curve where it starts out as a wide-curve and then bends sharper before straightening out.
While leaning through the wide-curve part I encountered some 'sand/gravel' mix which must have come off of a dump truck (just guessing at this). It was dark enough in the morning and the nice slippery addition to the road was spread out enough I was not able to see it. Well I felt it. Rear tire kicked out to my right and immediately and I was feeling the bike starting to go down. I was able to bring the bike 'upright' very quickly. Now I'm faces with another problem. When I took out the lean on a bike when the road/on-ramp is curved I was now heading almost stright into the short 3-4 foot Jersey barrier and ready to go over the barreir and dump myself 20ft below.
I wasn't sure if the gravel/sand mix was still there and all I could do was simply give a little counter steering lean at a time (as much as I felt I could give it) and trying to use a little brake but not too much as I didn't wanna lock up the rear on the gravel/sand. Now I'm into the little gravel nibblits which collect on the side of the road. I kept braking as much as I dared and giving leans to try and get away from a head-on with the barrier. by the time I reached the jersey barrier my bike was no longer 90degrees perpendicular to the barrier but now at about a 20-30 degree angle to it. Last split second before impact I counter steered a lil extra and since I was in the outside of the lane gravel crap my rear slide again to reduce the angle even more. I ended up NOT hitting the Jersey barrier with my wheel/fender but instead my locked-out hiway peg took the brunt of it. It hit the barrier pretty well and kept the bike from going into the barrier. I did regain better control of the bike once it slowed down to probaby 30mph and was able to get 'off the barrier' . My Right outside hiway peg looks like it was taken to a grinder for a few minutes. Took off almost 1/4" of metal from the peg from the initial blow and then scrape.
Granted it is hard to put all the facts together 100% accurate as this happened in the span of about 2 seconds (from initial loss of rear tire to impact on the Barrier). I've tried to replay this in my mind several times as to the events that happend and how I reacted. I know my first reaction is 'don't fall over the barrier to the road 20ft below. 2nd was ... don't lay down the bike.
I know there are those who will say .... 'if all that happened is losing 1/4" off of a highway peg.... then you handled it perfectly ". I'm all about 'learning. I know there are lots of 'almost' bad accidents and those who have a lot more experience riding than I have. Just wondering if/what I did that maybe I should have done differently to avoid glancing off the barrier to begin with?
My first thought was that you were probably a little too fast for the curve, at least faster than I normally run a curve, but I do accelerate after entering the curve, so that may be where you were when you hit the sand -- not something that I would have expected to encounter either.
I'm just glad you were able to get out of it with as little damage (and no injury) as you had.
Thanks for the post -- you may very well be saving someone else's life. [sm=thanx.gif]
At first I thought about replacing my peg but thinking about it for a few min .... I came to the realization .... that it is not too visible and... it goes with the story. I consider it a little battle-scar that I happen to win the little skirmish. Also gives me the reminder when I wash the bike that I was fortunate and it was somewhat evident the good Lord didn't feel my time on this earth was done.
Glad you had a save... Sometimes these are the Best lessons learned -
It also sounds like you might have delayed your turn a little. It's good to go to the outside for a better view, but it means you need to lean more to make the turn. A little slower / a little closer to the inside would be my hindsight call. Without knowing there was sand in wait, though, I'd probable have taken it wide myself.
Good save; glad you made it.
