Death Wobble
Old Sep 25, 2018 | 10:16 AM
  #71
grbrown's Avatar
grbrown
Exclamation
Originally Posted by jjavman
Right now I am in the process of waiting for a new rear tire install on the '10. This leaves me with a Michelin Commander II on the front (new), and a rather worn Harley Dunlop on the back.
I shall repeat that stretch of road when I get the new tire to confirm.
JJ
Remember to run in your new tyre for a couple of hundred miles and to check pressure, before attempting your high speed run! My brother slid off once on a favourite bend, celebrating having his new rear tyre fitted, so be warned.
Old Sep 25, 2018 | 10:27 AM
  #72
bagman1's Avatar
bagman1
Default Death Wobble
dont forget to look at your swing arm bushings and your motor mounts. They are all related and presuming your mileages are up there it may be crucial to a correct alignment. HD bushings are junk after about 30k miles anyway.
Old Sep 25, 2018 | 08:55 PM
  #73
Long lonesome highwayman's Avatar
Originally Posted by bigskyroadglide
the wobble was very well documented in the pre 09 frames with a number of aftermarket suppliers offering various remedies.
the culprit, IMHO, which has been a constant, in pre 09 frames are the cleve bushings in the swingarm and the flex from the rubber biscuits. replace the bushings with bearings and supplement the rubber biscuits with an insert and movement, or rear steer, is greatly, if not 99% eliminated.
on post 09 frames, the actual stiffness overcomes the majority of these design choices, but can still benefit from component upgrades in the same areas.
my 04 at around 90K miles would give a rear wiggle in long sweepers. bushing replacement with bearings eliminated that feeling.
on my 10 and 12, i have pushed to fairly strong triple digit speeds and have never felt a wiggle or rear steer. perhaps i wil, but to date this has not occurred primilary i believe due to improved frame stiffness.
my .02
When you say pre 09, does that mean all pre 09's including the older classic and vintage models? Is it just baggers or Sportsters also?
Old Sep 26, 2018 | 03:37 AM
  #74
grbrown's Avatar
grbrown
Wink
It applies to the earlier rubber-mount Touring models, from 1980 onwards. Buells and Sportsters with rubber-mount engines have a superior system. Some older rigid-mount bikes had handling problems, unrelated to what we're talking about here. Current rubber-mount Touring bikes are not perfect and can display handling problems, down to the design H-D has employed. For more info read my thread linked at post #64 above.
Old Sep 26, 2018 | 09:58 AM
  #75
rocket23's Avatar
rocket23
about all i do is check the tire pressure........might be selling the bike anyways.dunno yet, but no problems yet knock wood.
Old Sep 26, 2018 | 12:30 PM
  #76
DAVENRINO's Avatar
DAVENRINO
I lost a good friend this year due to "death wobble". But, he was on a 2018 BMW 800 GSA and went into a tank-slapper at 65 mph. Granted, he was loaded for a trip around the world, so it could have been a CG/overloading issue.
Old Sep 26, 2018 | 12:39 PM
  #77
Z's Avatar
Z
damned sorry to hear about your friend. Motorcycles kill, plain and simple, and we can "yeah but" this accident all day long. May he rest in peace and may his family find peace with their loss.
Old Sep 26, 2018 | 12:41 PM
  #78
Z's Avatar
Z
Had slow but substantial weave in high-speed sweepers from day one of picking up my 2000 Glide. Installed Progressive shocks all around and a Bagger Brace and it's tracked like it's on rails since.
Old Sep 26, 2018 | 12:46 PM
  #79
rocket23's Avatar
rocket23
truer words were never spoken.
x 2 on the rip
Old Sep 26, 2018 | 02:06 PM
  #80
Hurricane19's Avatar
Hurricane19
Coming into this thread rather late, but had it happen to me yesterday on my '10 Ultra on a sweeping curve. Speed was 85+
First time it happened on this bike, but also happened on my old '05 Ultra at about the same speed.
My theory (and I realize there could be several causes), is tire mismatch.
When I replaced the tires on the '05, I never had it happen again.
JJ
My Theory is this a 900lb touring bike that really isn't designed to take turns at 85+ mph. How many people have you guys heard of having death wobble when doing the speed limit, or at least within reason?? I personally run my SG harder than I should but still haven't experienced this.
