LED Headlights for My Road Glide
Old Apr 30, 2017 | 08:30 PM
Kburgad's Avatar
Kburgad
Bar and shield daymakers in black housing. They look great on my scoot. Work even better than they look.
Old Apr 30, 2017 | 10:56 PM
bklynbob's Avatar
bklynbob
JW Speaker.
Old May 1, 2017 | 06:44 AM
PingJockey's Avatar
PingJockey
It depends on what your needs really are. A lot of people like the daymakers, and sure, they are bright as heck. But, they suffer SEVERE tunnel vision, at least from what I've seen. I needed something wider, as I ride through a lot of unlit wooded roads with turns and animals lurking in the tress.
On recommendation from my dealership, I went with Cyron Urbans. They are almost as bright as daymakers straight ahead, but the wide angle side illumination is the best I've ever seen on a motorcycle headlight. For the first time, I'm able to see into the ditches on both sides of the road. I'm very happy with my purchase, and it would take a marvel of engineering to make me buy something different.
Old May 1, 2017 | 07:15 AM
Road Hawg's Avatar
Road Hawg
Thumbs up
Sounds like what I'm looking for, I too ride through a lot of unlite canyons and areas with a lot of wildlife so being able to see a wide area would be beneficial. Do you have a website? Thank you all for the input, you have made my search much easier
Old May 1, 2017 | 07:38 AM
PingJockey's Avatar
PingJockey
http://www.cyron.com/p-236-headlight...ck-chrome.aspx
I installed the 7" chrome version on my road king. The link is specific to that part, but you can use it as the starting point to find the right part for you. The "Urban" series are the wide setups, so if there is an urban for your bike, it should be right.
Note that some bikes (like mine) need a mounting bracket. The instructions were crap, but it was a common sense install. It took me about 20 minutes. The assembly is also spring mounted, which they say reduces vibration. I honestly am not sure how well that works because I didn't have too much of a problem with that in the first place.
Old May 1, 2017 | 07:44 AM
PingJockey's Avatar
PingJockey
I also ordered the aux lights, but I did so through the dealership and have not picked them up yet. Even with the original lights, and the new Cyron headlight, the sides are great. I will update this when I have them installed.
Old May 1, 2017 | 08:41 AM
E8USMCRET's Avatar
E8USMCRET
Look into these http://www.socalmotogear.com/Harley-...-p/hrgleda.htm
I run a set of their passing lamps. The lamps are so bright I don't even need a headlight.
Old May 1, 2017 | 01:51 PM
RFG7680's Avatar
RFG7680
Here's the thread on roadglide.org
http://www.roadglide.org/25-lighting...ers-cheap.html
Old May 1, 2017 | 03:30 PM
Tenn's Avatar
Tenn
I installed these, they are good so far. http://www.ebay.com/itm/Black-LED-He...-/262236237382
JW speaker has some adaptive for a mere $999 http://www.jwspeaker.com/products/ad...ontent=slider3
then there is custom dynamic led with halo for $799 https://www.customdynamics.com/trube...d_headlamp.htm
Lots to choose from
TN
Old May 1, 2017 | 04:27 PM
tsigwing's Avatar
tsigwing
real happy with my daymakers.
