radio doesn't turn off
Old 05-05-2017, 11:23 AM
sdharon's Avatar
sdharon
sdharon is offline
Stage II
Default radio doesn't turn off
2004 Electra Glide. Turn off ignition & radio stays on. If I unplug the power from the back of the radio it will turn off & stay off when plugged back in until the key switch is turned back on then stays on again
Old 05-05-2017, 02:52 PM
2AMGuy's Avatar
2AMGuy
2AMGuy is offline
Received 2,667 Likes on 1,672 Posts
My guess is that U need to have your radio taken out and repaired.
You may get luck and find a dealer that has an extra radio on hand but the odds aren't on your side for this happening.
If you was to do the R&R it may be a faster turnaround time than having the dealership do the entire job and it would definitely be cheaper.
You may also want to check to see if you have a radio repair shop near you.
My brother had a radio in his '96 Impala that kept running his battery down and your problem sounds a lot like the one that he had with his OEM radio.
Old 05-05-2017, 03:14 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,650 Likes on 3,887 Posts
I really do not read in your text if you are saying radio will not turn off with radio switch. Obviously, someone has wired it straight to the battery and not thru the key on switch
Old 05-05-2017, 04:45 PM
ORradtech's Avatar
ORradtech
ORradtech is offline
Really, there's not enough information to even make a good guess at your problem. Either of the the two previous posters could be right. Or it could be something else.
Some questions I have are;
Are you the original owner?
Is it the original radio?
Has it been working correctly and just started this?
Will it turn off with the power switch? Either with the key off or on?
Has any work been done in the faring near the radio?
When the radio is working does everything work as it should?
Does the bike have any other electrical quirks?
If you feel like you need to pull it and have it looked at I would suggest contacting Iron Cross. They are pretty much the Harley radio specialist. Heck, I'd call them before I'd pull it out and see what they say.
Old 05-06-2017, 01:54 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,819 Likes on 1,069 Posts
I'm guessing that the OP doesn't know that there's an On/Off switch on the radidio!
Old 05-06-2017, 08:36 AM
ORradtech's Avatar
ORradtech
It should still turn off with the ignition switch. Mine does.
However, if the radio will turn off with its power button then the problem is likely in wiring not the radio itself.
Old 05-06-2017, 09:27 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
Once again, a post with ZERO value!
Old 05-06-2017, 10:30 AM
Hate Work's Avatar
Hate Work
Hate Work is offline
Maybe some people are just grouchy until they have had their 6 cigs, 4 coffees and 2 scotches. Maybe he will be better in a while.....
IzzoQuazzo
Audio Systems
05-26-2017 01:15 PM
oakmossy
07-02-2014 07:05 AM
myred55
06-30-2012 09:06 AM
harleykris
04-30-2008 05:46 PM
RonH
10-27-2006 10:09 PM
Quick Reply: radio doesn't turn off
