Load equalizer question
Old May 6, 2017 | 10:44 PM
ChromeJunkie's Avatar
ChromeJunkie
Default Load equalizer question
I have searched till I'm blue in the face. I want to install LED turn signals on my 2013 Ultra Limited and some have said I need and others have said that I don't need a load equalizer. So my question is do I need an equalizer for that bike. Thanks in advance.
Old May 6, 2017 | 10:53 PM
kevin_n's Avatar
kevin_n
We put custom dynamics led front and rear lights on my wife's 2013 sg and it DID need a load equalizer. Not sure about Harley brand led's but for custom dynamics it was needed.
Kevin
Old May 6, 2017 | 10:57 PM
ChromeJunkie
Thanks. These are custom dynamics led's I took off my 05 FXST I traded on the Limited, and I have an equalizer, but just not sure I needed one. Now I just have to see if I can remove the turn signal bar without having to remove the back tire so I can install the new light bar with bullet style turn signals. Thanks
Old May 6, 2017 | 11:01 PM
Veekness's Avatar
Veekness
...or you can wire in a standard light bulb in the circuit somewhere to give you a hillbilly load equalizer...
​​​​​​​Cheesy? Sure. Cheap. Yep. I reckon you could paint the bulb to keep it from looking too bizarre.
Old May 6, 2017 | 11:34 PM
skratch's Avatar
skratch
if you are just doing one end, either front or back, you can get away without a load equalizer. but, if you do both, you are going to need one.
Old May 7, 2017 | 06:27 AM
RANGER73's Avatar
RANGER73
^^^ what he said^^^
Old May 7, 2017 | 07:16 AM
rkc2006's Avatar
rkc2006
I purchased my LED bullet front and rear turn signals for my Road King from Custom Dynamics and they required a load equalizer. Very easy install.
Old May 7, 2017 | 07:33 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
The Biketronics EQ is simple plug and play, built to military specs. No separate power wire needed, it's all one plug in. Sweet.
Old May 7, 2017 | 03:32 PM
470004's Avatar
470004
I switch to the Kuryakyn LED front & rear signal lamps and they came with a load equalizer.
Old May 7, 2017 | 08:56 PM
J_ULTRA's Avatar
J_ULTRA
I bought the HD led turns for my 11 Ultra and they didn't need an equalizer.
