CB Not working problem
Old May 11, 2017 | 11:38 AM
Ultra Pearl's Avatar
Ultra Pearl
Default CB Not working problem
So my cb on my 08 ultra, does not receive or transmit. The cb icon comes on in dash, the volume is up, you can put it on any channel and turn off squelch and get noise, push the ppt button and the icon comes on in dash. The vox/intercom is working in headsets and in speakers. Doesn't matter where you set speaker switch. I have checked antenna cable, I have used the long and short antenna. Both were attached to the right cb side of tour pak.
The only thing I haven't tried is switching out the cb unit.
Any thoughts?
Old May 11, 2017 | 07:21 PM
Mr. Mike's Avatar
Mr. Mike
Have you checked (with a decent meter) the grounding on the antenna? From the antenna base mount to the coax connector, then from the connector to bikes grounding point. Little or no resistance is what you want.
Old May 12, 2017 | 07:36 PM
Ultra Pearl
So did some more testing tonight with another bike, seems like I'm transmitting at times, but can only receive with squelch turned off but the sound is very broken and you can make out what is said.
Old May 14, 2017 | 03:45 PM
Ultra Pearl
Default Update
So replaced cb module, and all is working. Bought a used module online and that did the trick.
Old May 14, 2017 | 08:39 PM
14GuineaPig's Avatar
14GuineaPig
Glad you got it fixed
Old Mar 5, 2019 | 08:01 AM
woowoo1945's Avatar
woowoo1945
How is the CB module grounded? 2013 Ultra Limited.
Old Mar 5, 2019 | 08:56 AM
skinman13's Avatar
skinman13
You could have a bad connection or ground in your power system somewhere that is creating a substantial level of RF noise which can cause receiver problems, but not usually transmission issues. Like back when copper ignition wires and bad points would wipe out the reception on your old AM car radio.
Your antenna or coax may have a problem and which may have already damaged your receiver and transmitter. The wrong or shorted antenna or coax cable will blow the final transmitter section very fast, and the wrong antenna or an open coax can reflect high level RF back into the receiver and damage the transmitter/receiver bidirectional switch which will damage the receiver front end causing problems like you are describing. I would not transmit anymore until you put a SWR meter on the antenna. If you do not have one, you need to get one or find someone who has one and knows how to use it.
Old Mar 5, 2019 | 03:31 PM
ORradtech's Avatar
ORradtech
He replaced it two years ago and that solved the problem.
Old Mar 5, 2019 | 03:40 PM
skinman13's Avatar
skinman13
I hate it when I don't catch the date...
Old Mar 6, 2019 | 02:51 PM
woowoo1945's Avatar
woowoo1945
Thank you Skinman13. I will check with my Harley friends for someone with a meter.
