Makes winding noise
Old May 31, 2017 | 01:43 AM
Dagnabbit's Avatar
Dagnabbit
Stage II
Default Makes winding noise
2001 Rd king makes a grinding noise when letting clutch out in first gear and feels like its jerking under load
Old May 31, 2017 | 07:08 AM
Livingmydream's Avatar
Livingmydream
check compensator nut. my 02 had the compensator nut come loose and what started as a whine gradually turned into a loud almost grinding noise. the compensator nut had come loose enough to turn by hand. good luck
Old May 31, 2017 | 09:23 AM
Dagnabbit's Avatar
Dagnabbit
Stage II
Would that also cause the motor to jerking or surge
Old Jun 1, 2017 | 05:12 AM
Livingmydream
That i do not know
Old Jun 1, 2017 | 05:15 AM
Jackie Paper's Avatar
Jackie Paper
Is the jerking filling after the clutch is out and engaged and you are running down the road? Or are you describing the actual clutch engagement?
Rev zombie
Sep 20, 2012 03:38 PM
Rev zombie
Sep 20, 2012 10:22 AM
Rev zombie
KCFLHRC
Apr 30, 2012 08:58 AM
Kim'sOldMan
Sep 1, 2010 12:32 PM
