Local road glide "project"
Old Jun 24, 2017 | 07:30 AM
matte's Avatar
matte
Default Local road glide "project"
So in searching locally for a road glide, I found something nearby. It's a 2012 with 21k miles which they're asking 9900 for. The kicker, it is missing it's hard bags. The selling point, I already own a pair of rushmore hard bags and a tourpak. Is there anything huge on later models that I should need to pass this up?
Old Jun 24, 2017 | 07:56 AM
matte's Avatar
matte
Ah as I look closer, looks like the stereo is gone out of the fairing.
Old Jun 24, 2017 | 08:10 AM
ORradtech's Avatar
ORradtech
I'd be very,very careful considering that bike. It sounds like it's either been mistreated or a project was started and abandoned. It's possible you could strike an advantageous deal but it will require a very close inspection and an understanding of what you want and what may have to be done.
There are garage queens out there for good prices and your bags will sell.
Old Jun 24, 2017 | 08:20 AM
matte's Avatar
matte
The more I look at it, the more it appears to have gone through the ringer. Will definitely proceed with caution. But if I could get it for 5-7k, might be worth the project.
Old Jun 24, 2017 | 08:22 AM
bigskyroadglide's Avatar
bigskyroadglide
a 2012 for 9900? make certain it runs and rides. no salvage title, then make you best offer to the man.
for that price, if you own the bags and tp already and it only needs a radio that you probably would replace anyway, its coulb be a reasonable deal.
Old Jun 24, 2017 | 09:03 AM
matte's Avatar
matte
Last question. I read that there are methods to make the rushmore bags fit on the pre-rushmore brackets. I am not worried there. Can the rushmore stock support brackets (I have them as well) bolt right up to the pre-rushmore fender? Looks like it will, but hard to say for sure.
Old Jun 24, 2017 | 09:37 AM
bigskyroadglide
ive never tried it but there are some that have. seems almost anything can be made to work.
frame is essentially the same except for the front end
Old Jun 24, 2017 | 12:19 PM
Kburgad's Avatar
Kburgad
Its real easy to make em fit. Just have to loosen the mount brackets. Adjust to line up. Retighten brackets. Just put em on a buddies 2008 off a 2016.
Old Jun 24, 2017 | 02:49 PM
t. sawyer's Avatar
t. sawyer
how does it run and ride?
Old Jun 24, 2017 | 03:13 PM
OldPhat's Avatar
OldPhat
If it sounds too good to be true, it usually is.
Check the Bike out very carefully, give it a good once over from top to bottom.
Fiend out all that has been done to the Bike, like a Stage-I, and what missing from it.
John
