Tire Pressure
After a year of no changes, I now check pressure beginning of each season, mid season & before winter storage although I never needed to add any air. Now at 5 years 14,000 miles same thing!
Although got a flat on the rear tire over the weekend, (picked up a nail) so there goes a perfect record lol.
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
To steal ideas from one person is plagiarism; to steal from many is research.
as above, why are you just adding 2 to the front, the weight is on the back tire.
I agree with 38/42, have you found a reason to drop to 40 solo?
BTW, have not cupped a tire since the 2lb increase.
I did have it at 44 rear once loaded down and found no issue. I have also lost a rear tire with low pressure on one long trip, but that was due to a f=defective tire gauge telling me I was at right pressure.
B Bop
For the life of me cannot understand why motorcycle tires generally do not hold their air well. My automobile tires never needs air either.
My old kicker for work 1999 Grand Cherokee has a slow leak on one tire but I know it's a bad valve stem, putting it off for few months as it will need tires soon.
Buuuuut I'm amazed how often riders need to add air.
B Bop
It appears everything in my life sucks, except for my vacuum cleaner. WDB
This topic tends to be over-thought quite a bit. There is some fairly significant pressure leeway when it comes to tires. Hand wringing over 1-2 psi adjustments, which no doubt would tax the accuracies of commercial pressure gauges anyway, ("reading" error is at least +- 1 in most), isn't worth the attention it seems to get.
Visually check your tires as part of your pre-ride check and check pre-ride pressure "for consistency". You're good to go.
FWIW, (which isn't much since my ride is so much different from yours), On my 2014 BO I run a 120 front tire and a 250 rear with 36 psi in both. This has proved optimum for me. I didn't arrive at these pressures in an arbitrary way. There is a method. Without getting into it, you'll do just fine with your Dealer's pressures. The real point is that these are tires, not surgical equipment, and they aren't as sensitive to incremental pressure changes as people like to think. The probable reason for all the pressure apprehension is that whenever a tire does fail, no matter the ultimate reason, the first thing the rep. / salesman is gonna blame is "pressures" because that's a customer responsibility. Pump your tires as hard as you like, thats no absolute guarantee they won't fail,, any more than running em "a bit" on the soft side is any guarantee they will. As a rule of thumb, when you measure cold pressure and then measure hot pressure, the difference should fall within 10-15 % of cold pressure.
Note:The person with only one tire pressure gauge will always know exactly what pressure is in his tires, the person with two gauges will never be quite sure.
