Compression questions???
Old Jul 12, 2017 | 07:52 PM
bigpayback21's Avatar
bigpayback21
Default Compression questions???
I recently did the 106 build with Andrews 57 cam and rush wrath, ss quickie pushrods, ss Lifters I just got around to doing a compression test and got 180 in both front and rear. On the bigboyzheads I put my setup in and should be getting close to 200. I'm thinking it's a pushrod adjustment, stretched timing chain not sure. But since the compression is even I don't think I'm off a tooth curious to hear your thoughts. Any suggestions would be appreciated.
Old Jul 12, 2017 | 08:29 PM
0ldhippie's Avatar
0ldhippie
Did ya disable the compression releases?
Old Jul 12, 2017 | 08:31 PM
bigpayback21
I have manual releases. They are in the up position during the test.
Old Jul 13, 2017 | 10:30 AM
Roadflyer's Avatar
Roadflyer
It's not a pushrod issue, I doubt the timing chain as well.
There's nothing wrong with 180 psi- don't get too caught up in the internet tuners saying you gotta have 200 psi.
Maybe its just the gauge? I have 2 compression gauges. Both have about a foot of hose, one has a schrader valve right at the plug threads, the other has the schrader at the gauge and nothing at the plug threads.
Because of the volume of air in the hose, the one without the schrader at the plug threads always reads about 20 lbs less.
Old Jul 13, 2017 | 11:06 AM
dab102999's Avatar
dab102999
How many miles on the rebuild? Are we sure everything is seated good.
Old Jul 13, 2017 | 11:35 AM
Veekness's Avatar
Veekness
I see no problems here. As long as they are pretty much equal, all is good. I've never heard of a timing chain on a Twinkie stretching enough to cause a problem, plus I don't think it would impact compression if it did...it'd have to be pretty dern sloppy!
So, relax, all is well, methinks...ride that puppy!
Old Jul 13, 2017 | 12:13 PM
bigpayback21
Thanks for the responses.
There's around 600-700 miles on this build. Both cylinders are right at 180 within 5 of each other. After putting the information in the calculator a 15 to 20 difference sounds like something Is wrong. I'm currently stationed in Hawaii so the sea level factor went out of the equation....
Old Jul 13, 2017 | 03:24 PM
bigpayback21
Thanks for the vote of confidence Im starting to think the gauge maybe off. Just checking all my odds and ends to make sure everything adds up.
Old Jul 13, 2017 | 06:26 PM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
Did you have the barrels off ? And if so, did you put new rings on the pistons ? Sometimes a detail in the story is missed, just trying to help you my friend.
__________________
LONG RIDE SHIELDS
www.longrideshields.com
Old Jul 13, 2017 | 09:18 PM
0ldhippie's Avatar
0ldhippie
Your cylinder cc measurements could be off, Or the intake cam could be off...
